Question about Sony XPLOD CDX-GT200 CD Player
Not able to load CD
Whenever I try to put in a CD it spits it straight out again, it will not even suck it in first. I've tried several CDs, and I am sure it is neither that I have inserted the disc iincorrectly or upside down, or that there is already a disc in the machine - the two troubleshhoting suggestions in the manual.
If you can't suggest anythnig simple, who might be able to fix this sort of thing, and will it have to go back to the manufacturer?
Re: Not able to load CD
Check your manual to see if a screw holding the cd player in place during shipping was used and if so, was it removed.
Posted on Jan 09, 2008
0 characters
3 Points
Cd player wont load
It is hard to fix factory radios. Most times the only way to fix it is to buy a new one.
May 25, 2014 | Rockford Fosgate Car Audio Receivers
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
I have a sony explod head unit installed in a 1987 volvo sedan DL and I left the cd in it over night so Im almost certain its either warped or damaged because the cd player will not spit out the cd at...
try operating on the patient
remove and open it and see what you are able to remove safely
if you get it out try it again and then if works lesson leaned dont leave cds in it, if you does it again youll need a new cd player
Jul 15, 2010 | Sony XPLOD CDX-GT200 CD Player
Cd player took all six of my cds now they don't
If you know how to remove the radio then open the unit and remove one by one. Make sure you are ejecting cd's properly.
Oct 23, 2009 | Car Audio Receivers
Wont play CDs
HI, this is optical lens assembly failuer. you will need to send this unit in for a optical lens replacement procedure. this procedure is costly and, you will need to ship it as well to the manufacture for this repair.
The actual issue is the lens is unable to track due to the assembly failuer(load/tracking motor malfunction).
You may be able to contact a local tech that will be able to order this assembly and repair it locally for you. this is unlikely but, its cheaper than sending it off.
Jun 01, 2009 | JVC KD-G420 CD Player
CD's keep spitting back out of player which is in caravan
The drive(optical) drives door mechanism has malfunctioned. If the PC CD drive can be replaced that would be the best, but repairing is also not cost-effective...........sodeep
May 12, 2009 | Sony CDX-L400X CD Player
Playing copied cds
go out and get a cd player lense cleaner cd and let it run for the time it gives. It is more than likely a dirty laser lense. Good luck.
Jan 06, 2009 | Kenwood KDC-2011S CD Player
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
Won't let me insert a disc
Try cleaning the unit with a laser lens cleaner disc and see if this helps at all. If not it sounds like your laser assembly may have failed.
Sep 09, 2006 | Clarion DXZ555MP CD Player
Sony XPLOD CDX-GT200 CD Player Logo
87 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
