Question about Genie Company GV150 Wet/Dry Vacuum
I have a Genie 200ph wet/dry vac. it has a long thin bag inside that catches everything. where can I get new ones and a manual
  • 11 Answers
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Posted on Mar 08, 2010
ftw1952
  • 10319 Answers
SOURCE: Where can I fet parts for a Genie SV300Q wet/dry
Depending on what parts are needed Home Depot for instance carries parts for these
Posted on Apr 13, 2010
SOURCE: how to set up wet dry vac for water pick up
you take the filter off and empty it.
Posted on May 01, 2010
  • 4088 Answers
SOURCE: my genie 10 gallon wet dry vac is hardly picking
Check the filter in the vacuum to see if it is plugged. Try removing the hose to see if there is better vacuum at the machine. Is there a hepa filter in the exhaust that might be plugged. Hope this helps!
Posted on Sep 26, 2010
stewbison
  • 577 Answers
SOURCE: Have a Genie 1.25 HP
Used a roll of toilet paper that what I used when I was drag racing. I am sorry that junky, sorry. Contact you local vacuum cleaner repair shop and see if they one on hand. Go to the Internet and for Genie Vacuum Cleaner web side. I'll bet you they will have it, order more than one. GB...stewbison
Posted on Aug 21, 2011
Where can I find a filter for genie sv300q?
I have the Genie 3000 which is a 20 gal. wet/dry vac with a 3.0 HP motor. I had bought at Home Depot some 20+ years ago. I bought a replacement filter at HD made by someone other than Genie and claiming to fit my model...but it did not fit...too loose to stay in place. I did track down some hypo filters that might fit...but at $28+ for the filter I decided it was time to get a new model with better and cheaper and available filters. I bought a Ridgid WD1451 14 gal with 6.0 HP. It is so much nicer and quieter. HD regularly carries the WD1450 for $99 or so. The WD1451 is the same model but also had the car vac hose and attachments (a $40 set) included for free. That was a limited offer probably no longer available. Get you a new one and enjoy it...I did...and I still have the Genie...but I think I'll toss it because it is too big, too loud, and I love this new Ridgid.
May 28, 2014 | Genie Company GV150 Wet/Dry Vacuum
Apr 13, 2010 | Genie Company GV150 Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Genie Company GV150 Wet/Dry Vacuum Logo
466 people viewed this question
Top Genie Company Vacuums Experts
Jim Parker
Jim Parker
ugeeks
Level 1 Expert
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
