Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence /ic chips
My phillips 60pp9202 rp tv is giving me blue problems and I see that you say to get the ic chips replaced ...any idea how much this should cost ...a ball park figure I just dont want to be ripped off.
Thanks alot
Geoff
  • bubbles68 Jan 14, 2008
    tvdork
    jshermanHey Guys thanks for the info , do you know the part numbers I should be ordering from electronix.com , also is it pretty straight forward to do ....I am quite handy but no pcb expert .
    Thanks again Guys
    Geoff
    Problem Solver:
  • 14 Answers
I got the convergence amps from www.electronix.com for $10 each, plus a couple bucks for some heat sink compound. I also purchased a good quality solder and a solder sucker while I was there. It's a good outfit and they were very responsive.
Posted on Jan 14, 2008
  • jsherman Jan 14, 2008
    For the 60pp9202, you'll want to purchase two STK392-120. Just go to www.electronix.com and search for the part and it'll take you riht to it. Be sure you purchase or have some heat sink compound too! You'll also need a low wattage solder pencil, solder sucker, and good quality solder, which you can also pick up there if you don't already have. If you need further tips on this task, let me know.
I just did it myself and it ran about $80. Make sure you get the IC's (2) and I would replace the 12 resistors.
Posted on Jan 10, 2008
Im looking for a projection alighment chip for 60pp9202/17f phillips
you will require two of the STK392-120 Convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305 - DPTV335 convergence repair kit available from www.tvrepairworld.com has the two ICs and the 12 resistors plus the CD with repair instructions.
Sep 25, 2011 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60PP9202 60 the blue convergence going down doesnt work it goes so far and it stops like it reached its. limit
xlt1873,
Since you can move your beams but not far enough the convergence ICs are good. Your porblem is with the digital convergence box. You will need to replace it.
I have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which will help you complete the reapair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 27, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202 60 in
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 08, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
  • Screen looks 3D
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
60PP9202 No Color
Bad chroma processor or related component....accordianman
Sep 25, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
