Question about Hotpoint Dishwashers
The model number for the hotpoint dishwasher is HDA110S48BA. The washer had water inside once the cycle finished and the dishes were not fully clean.
Falling Down
  • 67 Answers
SOURCE: Dirty Dishes after dishwasher has finished
You may be getting sand in from the supply lines. Fill a clear glass container from the sink a few times and look at the bottom for sand particles. You may be getting sand from a pool filter? Remove the filter from the faucet head (it should unscrew) and look for sand particles in it. You may not be getting them in the kitchen sink if the dishwater inlets are below the sink as the particles may be sinking to the bottom of the pipes. You may need to put a filter in the dishwasher inlet. Try filling the dishwasher by hand with bottled water once and then see if the sand is still there. If so, it probably comes in through the water supply.
Posted on Nov 30, 2007
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
Illeagle
  • 525 Answers
SOURCE: Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
http://www.repairclinic.com/0088_9_1.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
SOURCE: Kenmore elite dishwasher 665 purchased in 2001
On our stainless tub kenmore elite diswasher model # 66515912001 (665.15912001), we removed the lower spray arm by turning the nut (try clockwise and counter clockwise) and lifting it off the lower unit.
Then, we turned the attached water port (that feeds the upper arm) to the right. It felt like it was going to break, but didn't !!!
Next, we removed the lower starfish looking thing on which the screen is attached by four torx head screws. Here we found much hardened yellow "stuff" that came off with hot water, a knife and shop vac. By my estimate, the screen was 60% blocked.
We also removed the upper tray so as to remove the upper arm. Banged it against the sink a few times to loosen the same caked on yellow "stuff" from inside it. Here we noticed many of the water outlet holes were completly clogged.
We also replaced our heating element because it was clearly flaking away. This required the dishwasher to have it's power shut off, water supply disconnected and pulled out. In the end, very easy to replace if you're mechanically inclined (I am very).
After a test run, my wife said: "haven't seen water dripping from the top tray in years..."
Total time investment for the above was about 3 - 4 hours.
Posted on Jul 29, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
After a power surge yesterday my hotpoint dishwasher is doing this halfway through the cycle. It doesn't finish the cycle - water stays cold and it doesn't dry the dishes - any ideas's? The model is
Try cutting off the power to the dishwasher at the breaker box to reset the memory board ( for 15 sec.) then turn the breaker back on. If this did the trick good if not then the power surge may have over powered the board inside.
Oct 14, 2012 | Dishwashers
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Doesn't clean
is your water heater set at 120 degrees if not set it to it
Mar 28, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Low water pressure
could br a impeller promblem on the wash motor
check the spray arms to see if the outlet holes are blocked
Dec 29, 2007 | Hotpoint 24 in. HDA2000Z Built-in...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
