Question about Radio Communications
The splitter went out on my big screenTV. I was checking on a price for replacement
  • 566 Answers
Depending on your t.v brand. I`ll give you an example on rca, the h.v splitter cost around $30 for a substitute and about 60 to $70 for the real mc`coy.
Posted on Nov 16, 2009
Sony 60
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
Feb 20, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
I have a built in video card but it does not support multistreaming.can i fix this without buying a new video card,
If by multistreaming you mean to two displays at once there are options with VGA splitters
http://www.tigerdirect.ca/applications/SearchTools/search.asp?keywords=vga splitter&sort=Price&dir=asc
http://www.national-tech.com/buy/vga-splitters.htm
http://www.maplin.co.uk/Module.aspx?moduleno=218645
http://www.maplin.co.uk/Search.aspx?menuno=85799
If you mean somthing else then to need to be a little more specific.
Buying a new (proper) video card is my reccomendation as many of them have two outputs and even facilities for hooking up to big screen tv's and regular tv's.
The prices for some of the splitters are more than the price of a proper card
Your computer would also benefit from a proper card with increased speed esp. for games and if your computer shares its memory with your onboard adaptor you will gain that memory back for the system with more benefits in that area too.
Aug 10, 2009 | Computers & Internet
RCA projection P46732BA no power and arcing sound
The High Voltage Splitter is the cause of this and replacing it should fix the problem. Their should not be a shock hazard once power is diconnected. But just incase, ground each of the anode leads from the crts to ground. That should take care of any HV charge from the CRTS. Do make a note of which wire went went where, that is important. When you get the new HV Splitter, you will need to transfer the small board that is mounted on the old Splitter. Again, be aware of where the wires hook up to it and you will be fine.
Hope this helps,
Skyassoc
Jun 18, 2009 | RCA P46921 46" Rear Projection Television
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
I have a avr-5808CI, when I hook up my bluray player with hdmi cable the blu-ray says 7.1dts hd and my system only outputs 5.1 dolby. I know you need 7.1 analoge out but is my system so obsolete. Is there...
no way to upgrade your pre-amp, but you can just use some simple little RCA Y-Splitters on the rear outputs to essentially give you 4 rear outputs to your amp like with 7.1.
however, true 7.1 each signal is unique.
at some point when it comes time to upgrade, check out Outlaw Audio. They make killer stuff at factory direct prices.
http://www.outlawaudio.com/products/990.html
Feb 27, 2009 | Audio Players & Recorders
Tv turned off and started beeping noise
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Jul 20, 2008 | RCA P52926 52" Rear Projection Television
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
