Shows paper Jam on Canon 720 PC photo copier
Paper starts out from paper drawer and only moves about 1/4 inch.
Hand feed does not work. Both cases shows paper jam light.
chuckchicki@hotmail.com
    Sergeant:
  • 329 Answers
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Posted on Nov 19, 2009
  • Jim Keysor Nov 19, 2009
I don't have the paper tray. Can I feed photo paper into it by hand?
Yes you can one at a time but you need to have it positioned correctly or the machine will not feed the paper in straight and you will wind up with a paper jam.
Jan 10, 2016 | Canon Selphy CP510 Thermal Photo Printer
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
91 people viewed this question
k24674
jasbo
jasbo
