Question about Timex Ironman Triathlon 30 Lap Watch T5E901
How do I remove unwantedoccasions/dates from the occasions mode
How do I remove unwanted Occasions/dates from the occasions mode,
there are no instructions in your product information page
I received, in 5 different occasions. slowing down to make a right or left turn,an audible alarm followed by the word "Fluid" It stays for 3 seconds and goes off.
Check various fluid levels such as oil, brake, cooling, power steering,etc. If indicator goes on primarily when making a turn I would check the Power steering fluid first.
Aug 25, 2017 | The Watches
My Casio wave captor watch keeps reverting to Jan 1st years ago. I have taken it back to the Casio dealer that sold it to me on several occasions but all they ever do is manually reset it and claim that...
i think you have a dud, i would conatct casio directly.
this model is radio controlled so will always set it self to the correct local time , i can only think that the watch is switching off an on causing it to reset the date then when it picks up the signal it resets the time.
Sep 18, 2017 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Raymond Weil Jasmine losing date everytime I go to wear my watch which is really on special occasions i find that I have to wind the watch to get the date right would this be a simple battery issue?
the problem is some month's av 28 days and some month's av 31days, but on your watch the wheel that as the numbers on has 31 days so if there's a month with 28 days you'll need to change it manualy hope this helps you,,
Aug 01, 2013 | Raymond Weil Watches
I have the Haurex Italy Promise Women's Crystal Watch. I bought it in June of this year. The watch stopped running today. This may not be relevant but I do not wear a watch very often, keeping it more...
It is unusual for a quartz watch to stop so soon (presumably the battery is now dead?).
I suggest you contact the makers local customer care center and discuss it with them.
You can find their local service center by going to http://www.haurex.com/collezione.asp?id=93 and clicking on "after sales service". If you have any proof of purchase date, then it should be still under warranty if it needs repair.
Dec 16, 2010 | Haurex Watches
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
My techno marine watch is not working. The battery was changed two years ago but the watch is only worn on special occasions. do you think it needs another batter. It is the diamond faced version.
That's right- your watch needs battery replacement. No matter you wear it every day or just once a year - battery life comes to an end in a two years time approximately. Expect the same all over and over again.
Rate me, plz.
Jan 07, 2010 | TechnoMarine Watches
I have an automatic watch that i don't wear that
Does it work when you wear it? If it does on those occasions then no harm no foul!!
Oct 06, 2009 | Rolex Daytona 116528 Wrist Watch
Lose or gain time?
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
Jan 18, 2009 | Dakota 2786-6 Wristwatch
Timex Ironman Triathlon 30 Lap Watch T5E901 Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
