Question about Printers & Copiers
Wont print it stop printing,there was still ink in refilled cartridges clean it but still didnt work so i sucked out the ink in cartridges .Then refilled with different ink still doesnt print thewindow says 100% normal .What could be the problem?Would the tubes maybe plugged if so how would clean them?
  • 589 Answers
Re: wont print
Look at the end of the cartridge and see if there is ink build up on it. If there is, you can run it under warm water (not the whole cartridge, just the print head). Do not "rub" the print head, as that will force ink back up into it. Let the warm water dissolve any ink built up on it. Let it air dry (no towels, etc).
Does it have more than one cartridge?
Posted on Jan 09, 2008
0 characters
3 Points
I recently posed a question about how to remove and clean a print head.
Cleaning wont hurt - but the heads may be worn out after 3 years of use.
If cleaning doesn't work, you may need to buy new cartridges and refill those when empty.
Jan 17, 2015 | Printers & Copiers
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
I suspect that your cartridge has a chip in it which is telling the printer that it is empty. You will either have to buy a new cartridge (or good compatible) or try to reset the chip
some advice on methods for resetting chips here
Mar 02, 2011 | HP Printers & Copiers
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Poor/no printing after refilling ink. have cleaned nozzle but didnt work.
Nov 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Not printing at all!
Change your cartridge and then try again
Sep 23, 2007 | Canon i9900 InkJet Photo Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
Printers & Copiers Logo
143 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
