Question about Garden
Please help my car trys to turn over but then just stalls. any ideas?
    President:
  • 1,486 Answers
If you have a key fob then the battery needs replacing.Its your imobilizer that is at fault.
Posted on Nov 16, 2009
  • 2,984 Answers
Sure! Would love to help!!! That's what we are here for!!!
Big problem for us to help you is.....
1. What type vehicle?
2. What size of engine?
3. What model of vehicle?
4. What year of vehicle?
5. What are the symptoms?
6. Have you changed anything?
This will help us help you.
Thanks!
I REMOVED ALL MY INJECTOR CONNECTORS EXCEPT ONE AND HOLD MY HAND OVER INTAKE TO GET IT TO START FOR A SECOND. 99 HONDA ACCORD 4 CYL. 5SPEED.WHAT COULD THIS BE CAUSED BY?
If it starts while holding your hand over the intake that tells me it is not getting gas. Is your choke working? Have you ever changed your fuel filter? A plugged filter will not let gas to the engine. do you have water in your gas tank? These are ideas to check.Could be dirty gas.
Jan 24, 2017 | 1999 Honda Accord
1999 Nissan Pathfinder won't start.
if engine management light lit up on dashboard you will need an obd scanner that then gives you the code to what is wrong.
Dec 26, 2016 | Nissan Cars & Trucks
I have a 2000 Chevy suburban 1500 LS it smells like gas when running real bad,when cold it starts fine when warm it takes 2 or 3 trys to get it to start, when running he has a rough time going from 0 to 30...
1. Is the Check Engine Light (CEL) on?
2. if it is, get an ODB II code reader and read the codes from the engine. There might be more than one code. (most auto parts store will do this for free if live close to an auto parts store)
With that code reader you can almost get the car to point you to the problem. Pull the codes from your car and post them and then someone can give you a more exact answer to your question.
Mar 22, 2015 | Cars & Trucks
I have suction where i put oil in, when i remove the cap the car trys to stall what do I do? 2002 montero sport limited
You don't add oil with the car running
You broke the vacuum for the crankcase evacuation
(PCV System)
If you have idle problems then they have to be diagnosed
Dec 06, 2012 | 2002 Mitsubishi Montero Sport
1996 ford taurus stalls when turning sharp turns
Check your fuel pressure sounds like it could be a weak fuel pump.If its not within the specs then replace the fuel pump and fuel filter.
Aug 24, 2012 | Ford Taurus Cars & Trucks
I have a loud vibration noise commin from in the trunk of my 2000 buick and it trys to stall out every once in a while. any ideas?
Sorry to say, but it sounds like the fuel pump is on the way out. If you haven't had your fuel filter changed in a while, now might buy you some extra time, but ultimately you will probably need a fuel pump soon.
Feb 23, 2011 | 2000 Buick LeSabre
Car runs but when put in gear stalls
if your car stalls or trys to lerch forward when stoping at a light or stop sigh, then your over drive is loked meaning you need to have your transmition serviced or the electrical to the lockup solinoide needs to be checked
Apr 12, 2010 | 1996 Pontiac Sunfire
2004 civic ,stalls
The stall is caused by either a problem in the electrical system or in the fuel system.
Get the fuel pump checked and the IAC valve cleaned, that should fix the issue, let me know...
Thanks
Smith
Jul 09, 2009 | 2004 Honda Accord
1994 cavalier major problem
Two possibles, you may have a short in the wire that acctuates the starter or your ignition switch is bad.If you want the procedure for checking these comment back and I'll respond this afternoon.As far as the stalling problem,I'm not sure,does it only do stall in a turn or stop?It's possible the baffle in the fuel tank has broke free.
Apr 02, 2009 | 1994 Chevrolet Cavalier
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
