Question about Vacuums
Help fix my 1997 sunfire
My 1997 sunfire will not go faster than 20 kms when i accellerate but engine run well just won't pick up speed
    President:
  • 1,486 Answers
Your problem is the air flow meter change it is the only answer.Good luck
Posted on Nov 16, 2009
My dyson stick vacuum not holding charge only runs for a couple of minutes
replace the battery
stick vacuums run for 20 minutes of normal speed and 5 minutes on boost speed
Jun 01, 2017 | Dyson Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My dyson ball fell over and now the ball won't roll properly and not picking up... Please can u advise how to fix the issue
I'm sorry to hear you're having difficulties with your DC24. If the Ball will not roll, it may be because the filter cover or HEPA filter are out of position. Please see the video below for guidance on how to check both of these are correctly fitted in place.
If the cleaner doesn't seem to be picking up as well as usual, I'd recommend running through these troubleshooting steps to check everything is correct with the machine:
http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
If you have any further questions about using or maintaining your cleaner, please get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 17, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Water spray not functioning for hose or carpet. I purchased this about 3 weeks a go. The spray work for about 20 mins then stopped. Is there are reset? I have tried turing off and on etc. Wendy...
Wendy,
I have the same model Bissell as you and this is going to sound silly....
The spray tank runs out of solution allot faster than you would expect it to. Remove the tank, dump out all the used stuff, and refill your solution tank.
You never know that it is empty until you dump out the waste tank! 20 minutes sounds about right for a full solution tank to run dry.
Good Luck! Thanks for using FixYa!
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
The motor in the power head ran at a higher pitch for a for 8 to 10 seconds then stopped. If I push the reset button the powerhead may or may not start or it may start and run for a few seconds. The brush...
Did you check the belt? A broken belt results in lower strain on the motor, causing it to run faster resulting in the faster speed and higher pitch. This could result in overheating, which will cause the motor to shut off.
If this isn't the problem you'll need to take it to the nearest Aerus Electrolux store for trouble-shooting and repair.
http://www.aerushome.com/storelocator/
Dec 29, 2010 | Electrolux C101 Bagged Canister Vacuum
Oreck XL upright - has a 2 speed switch. Now only works in high speed not low speed. Will a new switch correct or is it the motor
Your vacuum is fine. The switch can either run at full speed or half speed. You are running at full speed, you need a new 2 speed switch. You can pick them up at an Oreck Store for $29 or around $15 on eBay
Jan 17, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Can you put an 18 in. bar and chain on a poulan 2055 14 in ?
Have you considered a rental? Home Depot rents Makitas (Dolmar) with a 20" bar reasonably. Be warned running a Dolmar/Makita will make you question the value of your Poulan LOL. HTH
Lou
Dec 07, 2009 | Vacuums
The DC04 Zorbster runs slow, it still picks up but I am worried it will overheat. If I hit it at the front, the motor picks up speed until the next time I start it up. Can you help???
The problem is likely caused by either (a) a broken or worn microswitch operating lever or (b) a faultyt microswitch. With the bin removed, the lever becomes visible just above the filter upon which the base of the bin normally rests.
Replacement of either part necessitates dismantling the appliance. The necessary parts are available from http://www.espares.co.uk/parts/dyson/dc04-zorbster/p/1086/716/4/420621
Jun 23, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
Engine troubles
I haven't fixed it yet but I think I might have a solution for it. From the factory this thing had a 4 barrel carb and they put an equivalent size atomizer in it for the propane and over the years someone omitted the EGR system in it and propane is already a hot burning fuel so without that system in it it picks up idol speed when under normal operating conditions and when I put the system back in it should fix the problem...... I hope. thanks for quick response. Grant
Mar 18, 2008 | Vacuums
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
