I have a Kenmore 90 Series Heavy Duty Super Capacity Plus w/ Quiet Pak Washing Machine. Lately I only have hot water (will not operate on cold),and it stops for an hour or two when it gets to the rinse cycle.
  • bksavs Nov 17, 2009
    Thanks for your help. I'll try this when I get home today.
    This was helpfull. I'll try these steps when I get home.
  • 6,784 Answers
HI. usually when units of this nature have issues with hot and cold water distribution, this will lead to a failed water inlet assembly. This assembly must be inspected for damage. You will need a multimeter for the procedure. This device will allow you to test the electrical integrity of the valve unit.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first. If the valve passes all the above inspections, and tests, this will then, lead to a failed control sector. the control sector can be a control board, or a timer module. replace either the timer, or control board if the valve passes the inspection and test.
NOTE_ It would be wise to preform a hard reset, before proceeding with the inspection. To preform this reset, simply unplug, or shutdown the appropriate circuit breaker for five minutes. Once the time has passed, kindly re-introduce power to the unit, and try a new cycle. Observe the units actions during this retry after the reset. If the error continues to present itself, proceed with the inspection above.
Posted on Nov 16, 2009
Re: series 80 heavy duty super capacity plus quiet pak
it is a safety switch for a purpose
it applies the brake to prevent personal injury from people sticking they hands in a moving drum and wash
it will not hurt the machine, just the operator
fixing the switch is easy so why take the risk
Feb 04, 2017 | Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore 90 series heavy duty super capacity plus quiet pak washing machine leaks a small amount water from the bottom front of washer when running a wash cycle.
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Aug 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
