RCA SDTV 2006 has a sensor light on in the front of the TV and the TV will not turn on. Is it something I can fix or does it require a repair person?
  • 19,396 Answers
Hi.
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards.
Posted on Nov 16, 2009
2006 ilo sdtv code
ILO universal remote code - Fixya
www.fixya.com/support/t149216-ilo_universal_remote_code
ILO universal remote code There is no code for ILO TV in my universal remote codelist. ... I have a 27" ilo sdtv. Bought the ..... Sep 09, 2006 ' iLO 2600 Television ...
i have a ilo sdtv and the remote codes direct tv gives wont ...
https://answers.yahoo.com/question/index?qid...
Dec 18, 2008 - does anyone know what to do i can't even find the manufacture for this brand.
RCA 4 digit codes (3) - eliztech.com
www.eliztech.com/remotes/rca-codes-4digit-v3.php
RCA universal 4 digit remote codes for RCR3273 RCR3373 RCR4257 and R55L8_Code_02. ... ICE, 1065. ILO, 1054, 1133, 1168, 1169, 1206, 1230. IMA, 1035.
Does SDTV = ATSC tuner - AVS Forum ' Home Theater Discussi
Dec 09, 2015 | iLO Televison & Video
I have an 20" RCA TruFlat Digital SDTV that is
The problem sounds like a problem with a power supply or a power chip. These can be a cheap fix if you can find a cheap TV repair man, but expect to pay hundreds at a TV repair shop.
Mar 03, 2011 | RCA Televison & Video
My dad has a 27" rca sdtv truflat tv a 2006
there is a major fault in the main circuit board (pcb) and needs to be fixed its not a fuse it not a reset problem its a dynamic fault that could be from a bad resistor to a downed capacitor if you have knowledge of these components then check them using a multimeter find the faulty parts and replace accordingly. but if you have no idea then it will need to go into the repair shop. a lot of our customers ask us if the unit (tv) etc after being fixed will be any good or should they buy a new one. a good tech will fix the unit and in most cases it will be tweeked and work better but always get a quote up front and hold them to it within $50.00
best of luck to you
if you need further advice please feel free to email us at sonicboomelectronics@hotmail.com
merry christmas
Dec 25, 2010 | RCA TruFlat 27F520T 27" TV
When I turn on the tv the little green light comes on in the front but the tv doesnt come on and after it clicks off their some sparks or something flashing in the lower back right corner of the tv.
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Sep 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a rca, sdtv, 32", screen stopped working.
Nope, you have a bad part inside.
It's fix or replace time.
Jan 06, 2010 | Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
Tv powers on but light just blinks and no picture or volume
A blinking power light would indicate a problem on the chassis board located inside the tv. Possibly a failed flyback or other electronic component. Its not cost effective to repair when you can invest in new tv for the same cost as repairing the defective tv. I should also mentioned the danger of dyi troubleshooting of the components inside the tv. I do not recommend unless you are familiar with properly discharging the tube to avoid electrical shock.
Jul 25, 2009 | RCA F32650 32" TV
How to put cod in rca remote. for rca sdtv
press tv button, then press and hold setup button, then press power button several times until tv shuts off. As SOON as it shuts off, press enter.
Jul 05, 2009 | Televison & Video
I have a rca 27 inch tv modle # 27v514t sdTV.when i turn it on 2 or 3 seconds it shuts off
The cable running from the button on the front unplug it as soon as you get the tv to turn on it should stay on.
Jul 28, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
