Question about HP Photosmart 2575 All-In-One InkJet Printer
Remove and check color cartridge...how many times do I have to do this before problem will correct...have done it three times cartridge is new
    President:
  • 787 Answers
Try clean the contacts on carriage unit with piece of cotton and some alcohol.Then clean the contacts on cartridge with rubber.If this not help there is a problem in the carriage unit and printer need service.
Posted on Nov 17, 2009
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I put in a new color cartridge and my printer, not compatible..
Consider this: Using name brand cartridges is more expensive... but works. If you're using the name brand replacements... good. If you've chosen to use refilled ink, some of the features do not work as well as the original replacements. I used refilled cartridges in my Lexmark All-In-One and the "Ink needs refill" applet did not work correctly... so I turned it off...
Oct 25, 2009 | Office Equipment & Supplies
Printer would recognize black ink i have replace the in three times with brand new cartridges any idea what to do
Sounds like your new cartridges are not being recognized, correct?
If not done already please ensure each cartridge has any plastic packing strips (usually with a colored tab) off the outside of the cartridge. Vendors use these to cover the contacts and/or the print heads for shipping and can be tricky to see.
Otherwise please ensure no ink has spilled or leaked into the slot where your printer cartridge goes. Use good computer cleaning swabs or wipes to remove any ink spill or dirt there. Gold contacts should be clean. Good cleaning wipes or swabs will let you remove dirt and ink but not leave fuzz or strands of cloth in printer. At this time you can also ensure no paper or labels etc are left inside covering gold contacts.
Oct 21, 2009 | Brother MFC 420CN All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Apr 21, 2009 | Lexmark Color JetPrinter Z52 InkJet
Remove & check color cartridge
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Ink cartridge assembly not going to correct posy to replace black
Remove the cartridge and put it back in. If still it doesn't work, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the black pattern or no black appears at all, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
G%% color cartridge
You might have a bad cartridge or the contacts that marry to the cartridge to the machine needs to be cleaned.
Hope that helps...
Jun 18, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
249 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
