Question about Cameras
Memory card error
I have a cannon 850 ixus and i keep getting memory card error what can i do about it?
  • Envirocare Feb 28, 2008
    Canon Digitail Ixus 400 Camera.
    On switching on comes up with 'memory card error'. Tried different memory cards and sam error appears BUT sometimes, when switch on, camera appears to work with no problem. what is causing this intermittent error?
  • SammieD Jun 06, 2008
    When I trun on my camera a get "MEMORY CARD ERROR" and "CARD LOCKED".
    Sergeant:
    Champion:
  • 317 Answers
Check to see if the little pin on the memory card is set to "lock", this prevents the camera from accessing any of the data on the card causing this problem
Posted on Jan 09, 2008
Why will a picture on my memory card not delete?
the memory card might be set to safe delete on . remove the memory card and switch it off then try to reformat the memory card
Aug 16, 2014 | Cannon Cameras
Cannon IXUS IIS memory card error
Hello....
last week, i too had faced the same problem and got this recovery software for mac file recovery from memory card. You can also download the demo version and check the recovery results.
Jun 16, 2012 | Canon PowerShot SD110 / IXUS IIs Digital...
MY CANNON IXUS 210 DISPLAYS MEMORY CARD ERROR WHEN TAKING A PHOTO AND DOES NOT SAVE THE PICTURE
This problem is so common, especially with Canon Powershot cameras like your IXUS 210, that there's a whole blog about it here:
http://hubpages.com/hub/Canon_Powershot_Memory_Card_Error_Fix
It seems that the camera gives this error when it has problems reading/writing the card. The fixes they suggest there are to do with cleaning the contacts. It's pretty easy to clean the contacts on the memory card, but much harder to clean the camera. I don't suggest following the instruction to spray cleaner into the slot... that sounds like a recipe for getting it all over the inside of the camera!
I would start by cleaning the memory card's contacts. You can either use a solvent such as Methyl Hydrate and a Kleenex, or you can actually rub the contacts clean with an eraser (or if you're British you can use a solvent such as Methylated Spirit and a tissue, or rub the contacts clean with a rubber). It's probably worth looking inside the camera too, to see if any of the contacts are obviously bent in the card slot. I've seen that in a Nintendo DS which is similar. If a contact is bent, nothing's going to work unless you can get it back in place.
Mar 23, 2011 | Canon PowerShot SD3500 IS / IXUS 210...
I got a new 4gb memory card for my cannon ixy 800is camera but it says memory card error.the make of the card is apacer. Do you have any suggestions on how i can fix this. I have not tried to clean the...
A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 10, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Canon digital ixus 850is card locked! message
.....Open your memory card........Adapter And see There IZZ a ThiNg named Lockand UNLOCk That!!!! i guEsS that woULd Work.....
Feb 21, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Card locked
Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory Card Error
Check in the Manual that the camera can accept 2Gb.
If it say it can then return the card for replacement.
Feb 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Lost of pictures from memori card
The camera does not support low level format, so the pictures may still be on the card.
To _TRY_ to restore your images, get a USB SD-card reader (they are pretty cheap), and try a utility that restores files on memory cards, such as VaioSoft Recovery Manager 1.5
Jan 05, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
IXUS 850 IS memory lose
check your camera if their is built in memory some picture are stored , lost memory card we connot trace up, unless prior card lost you had been transfer to your pc.
http://thecoolpics.com/hot.jpg :x
Nov 25, 2007 | Canon PowerShot SD800 IS / IXUS 850 IS...
Memory card problem
hi
I was happily using Cannon IXUS 750on one of my long vacations when the memory card almost got full. perhaps I clicked once or twice to take a picture when the card was full. ever since the camera displays Memory Card Error.
These are almost all the photos I took on my camera since a long time now. Could anybody pleeeese help me in retrieving my photos and recordings?
thanks v much
Nahar
Oct 30, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
160 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
