Question about Sharp AR-M162 All-In-One Laser Printer
Thick black line in all copies on sharp arm 162e
    President:
  • Sharp Master
  • 1,447 Answers
Dear,
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Posted on Jan 01, 2010
Why do I get a thick black line down side of page when copying, but not when I print
Not sure, but one possibility is that your paper you are copying is not all the way to the edge of the copier. If there is a crack along the edge where light from the room can get in it will show up black in those areas. You will see the same effect if you leave the top of the copier off and try to copy something. There could also be something wrong with the scanner arm preventing it from moving all the way to the edge of the window.
Mar 12, 2015 | Canon Pixma MX452
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
Black thick line going horizantal on screen can it be fixed?
Usually a bad board but someone has to open set and troubleshoot to decide which board is the problem.
Apr 08, 2012 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
When you run a copy it leaves a couple thick dark lines on the paper that you copied too.
If you lighten the exposure do the lines fade away ? It most likly needs a drum or a drum cleaning blade. Good luck.
Jul 14, 2011 | Sharp AR-162S Copier
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I
If the drum is rotated in the proper direction, it should be clean. If the line on your copy is in about the same location from to back as the line on the drum then your only option is going to be to replace the drum unit. The drum unit contains a drum cleaning blade that is supposed to clean the drum as it is being rotated. This is apparently not working in your case. These cleaner blades can be replaced if you have someone locally that can do it. The cost of a cleaner blade is about $20.
Good Luck and Thank You for using Fixya.
Jul 09, 2010 | Sharp AL-1641CS Laser Digital Copier
Thick black line
clean the roller and the catridge reel
Jun 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Feb 25, 2009 | Lexmark X4875 All-In-One InkJet Printer
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
Sharp AR-M162 All-In-One Laser Printer Logo
187 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
