Question about Frigidaire FEB24S2AS Single Oven
My frigidaire oven is showing f10 and f30 - Frigidaire FEB24S2AS Single Oven
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite made by Frigidaire
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
  • 130 Answers
SOURCE: Frigidaire Wall Oven
It is telling you that your oven has an issue. Check your owners manual for the fault code definitions. If you have a model number I may be able to find it for you.
Posted on Jan 26, 2009
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire 24" Built-in Single Electric...
What does f30 mean on the read out
F30 = Open Probe Connection
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Hope helps.
Apr 25, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Apr 17, 2011 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
My oven gives an error code of F30 and the door lock flashes?
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Nov 16, 2010 | Frigidaire FEB30S5D Electric Single Oven
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven F10 Problem
PJC,
From the Frigidaire service manual:
"F10: Runaway Temperature.
SUGGESTED CORRECTIVE ACTION
1. (F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive."
-hopefully it's just a bad temperature sensor!
www.fixyourboard.com
Jul 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F30 Erorr on stove...
The fault code shows that your temperature probe opened.
1. Check resistance at room temperature & compare to RTD Sensor resistance chart.
2. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jun 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FEB24S2AS Single Oven Logo
82 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
