Question about Dell 1600n All-In-One Laser Printer
DELL 1600N HI MY DELL 1600N HAS LINES WHEN IT PRINTS COPIES
Great. thanks. that did it.
Posted on May 19, 2008
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Posted on Jan 14, 2008
Severe lines appear on copies. The cartridge is
Most likely it's the toner cartridge. Remove the cartridge, turn it over and slide open the cover over the drum. The drum is the colored cylinder running from one side of the cartridge to the other. Do you see what appears to be the same streaks going around the drum? The drum should be completely clean and free of any lines or streaks. If it has lines or streaks then the cartridge is bad.
Only other possibility here would be the scanner glass. Make sure your streaks don't go away when making a copy from the glass. If they do you could have dirt or trash on your scanner glass.
Good Luck and thank you for using Fixya.
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n prints very light. changed toner to no avail.
Jul 04, 2009 | Dell Office Equipment & Supplies
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
you need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
May 21, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Printer vertical lines
Looks like mark on drum.. Change the toner cartrige .. If the printer is older, could be that the exit rollers are worn out..
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Nov 08, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Freakels on Print
Cartridge. As always with print quality problems....Cartridge first.
Jun 26, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
277 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
