Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 20722990 washer. There's a smell
I have a Kenmore 20722990 washer. There's a smell comming from inside it. I ran it 4x with the hot water/baking soda/vinegar mixtures, but the smell is still there. I used some blocks of wood and lifted it up to see underneath, but it was clean. What should I do next? Could it be comming from inside the fabric softener dispense?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20722990
Thoughts are:
1. Fabric Softener dispenser. I'd remove it, run a couple of loads with just soap and see if the smell disappears.
2. These models use whats called a Motor Coupler between the motor and transmission. The center part of the coupler is a rubber device that could be worn and you smell the rubber "burning"
A way to check it is to remove the cabinet, pump and motor and see if the coupler is wearing.
Following is a description of how to access the coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=4f378f93259c747a96114e0e5fb5b352
3. Depending on the age of the washer, over time "gunk" can build up around the agitator shaft and in the tub. That could be causing the smell.
In order to clean it, you'll have to remove the agitator(s) and the basket. It's not a really difficult job.
See the following for how to pull the agitators, spanner nut, drive block and basket. You don't need a special spanner wrench. I've used a short 10" pipe wrench hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it. Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
With the agitators, and basket removed, I'd thoroughly clean the tub and any other gunk that you see.
Posted on Nov 16, 2009
My Kenmore 70 series washer sounds like it has something stuck in it and makes a grinding and buzzing noise the agitator will barely move but the washer will drain but not spin
That could be the motor coupler. It could also be the transmission. It is pretty easy to fix. I recently worked on my brother's washer:
Aug 04, 2012 | Kenmore 20722
Product = model 15962 Problem = really bad smell
A good trick that i found was to fill tub with hot water and put a full cup of dishwasher detergent any kind but has to be powdered not liquid detergent. Do this two times in a row and then every month.
Jun 10, 2011 | Kenmore 15962 / 15964 Top Load Washer
I have a Kenmore 70 series washer Model 110-20722990. I am trying to find out what kind of tub is in it (plastic or steel) and the capacity. I don't see this info on the washer anywhere. Thanks!
ceramic coated steel tub - 3.2cu ft capacity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore 20722
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
There is a leak from the pump of my kenmore top loading 20722990
If you type in "kenmore washer parts" you get 10 pages of hits on where to get parts. If you contact a local appliance parts dealer,I am sure he may have one on the shelf, it is such a common item.
Jan 05, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer/top load
Try Washer Magic, you can buy it at your local Menards, Ace Hardware or look at line. I have never used it.
Let me know how it works for you.
May 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Mar 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
