Question about Sony MDR-NC6 Consumer Headphones
My headphones just stopped working all together after less than a year of use, no wire or water damage
  • Sony Master
  • 5,167 Answers
If they are just the standard type, ie no built in amp etc, chances are that an internal break that is not visible to the wire has occurred. It is most probable that it's in the plug.
If it has a volume control built in suspect that first!
Are they covered by Sony still, check that out, before attempting any repair.
Posted on Nov 30, 2009
I have WeSC headphones. They are Banjar on-ear headphones, wired in. There are no visible damages. No sound at all. I don't wanna cut anything until I know what's wrong. Anybody have ideas?
Try getting a headphone amp. Battery powered and make sure you get one with no less than 3000 mah capacity.It will last more than 24 hours with 3000 mah.If more power does not help check wire connections in the headphones.
Jun 27, 2016 | Wesc Audio Players & Recorders
My headphone wire was cut into two parts how do I fix it
Just strip the insulation back to reveal the wires, there should be 3 wires, one for the left headphone, one for the right headphone and a shield wire.
join the wires that have the same colors (solder each wire together) wrap each wire with insulation tape so they do not short against each other and then bind the whole lot together.
You headphones should work again.
Apr 04, 2012 | Dell Computers & Internet
My left headphone stopped working after a year or so. How can i fix this?
The copper wires inside the cable have broken. Since you don't know where the break occurred all you can do is to open the left headphone, remove the speaker, cut a piece of the cord and resolder it to the speaker. Test it, if it's fixed just put the headphone back together. If not, cut another piece. If you must cut more than a third of the cable to get it working then it's dead, just buy a new pair.
Jun 30, 2010 | Sony Bud Style Headphones
Headphones only work if it is in a certain direction
You can fix this with some soldering skill and a lot of tinkering. its not terribly hard but can damage your ipod or what ever your listening to if you do it incorrectly. On the flip side im looking for a pair of the ear buds with out a cord for a new life in a project. If you need more help or may be interested in working out something email me. n_raven99(at)hotmail.com
Apr 01, 2010 | Bose in-ear headphones - Black with...
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Samson Stereo Headphones RH100 - no more sound
first u have to check the wire from pc to headphone whether any wire is damaged ,next u check whether the volume in the headphone is mute, and then check the pc volume whether it is in mute .rate as u like
Oct 16, 2008 | Samson RH100 Headphones
Noise concelling head hpones
Same here, my QC 3's stopped working, bought a new battery and nothing happened. Called Bose 1-877-210-3782 followed the prompts for "english" and "headphones". My QC 3's are 3 years old and out of warranty. Bose agreed to replace the headphones for $75 with free shipping. Better than paying a few hundred. Replacement set will have 1 year warranty.
Apr 27, 2008 | Bose QuietComfort 3 Acoustic Noise...
Sony MDR-NC6 Consumer Headphones Logo
444 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
