Question about Maytag Performa PAV3200
Maytag Performa...It fills up and will not spin.
I have a Maytag Performa model: #PAV3200AWW. For some reason it fills up with water and then won'f go any further. It will not spin..rinse...drain water or anything? I can hear the timer in it moving from one cycle to the next and the dial moves through the cycles and turns itself off. What is the matter with my washer.
I have a sneaky suspicion that its jealous of the new dryer I just bought Sat before last and its boycotting me. Please help me.
~signed
Do It Yourself Mama
  • fleming58 Sep 13, 2008
    Same washer, same problem....seems to be off balance.
  • Anonymous Nov 27, 2008
    Yep,
    My machine had the same problem.
    I found the drive belt had snapped and it was just lying on the floor underneath while the machine's timer would go through the motions.
Posted on Nov 27, 2008
Could also be the motor start capacitor - I've had it arcing at the base of the terminals where it enters the body of the cap. Genlty wiggle the leads and if one falls off, you've found the fault
Posted on Sep 28, 2008
    Scholar:
  • 196 Answers
There are to devices that can cause this. The lid switch and the water level control valve.
Posted on Jan 13, 2008
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Washing Mach. Maytag Performa PAV3200AWW has stopped during the washing cycle, and did not spin and emptied. Motor 'Humms', and belt looks OK. If I turn the control button, water filling only seems to...
(try this!)
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 21, 2011 | Maytag Performa PAV3200
(Try this!)
John C
Mar 21, 2011 | Maytag Performa PAV2200
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Sep 01, 2009 | Maytag Performa PAV2200
Maytag performa pavt144aww
lifht the lid up and down and listen carefully . do you hear a clicking noise ??? if not your lid switch is not engaging, unit doesnt think door is down its not going to advance into spin
Feb 24, 2008 | Washing Machines
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
251 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
