Question about Goodman GMS1155CNA Heater
Brought a control board it,s said that i need to reverse the pulartiy
    Scholar:
  • 111 Answers
Simply means to reverse the wires from the way you currently have it connected.
Now depending on the board, it may want low or high voltage to have the polarity reversed.
If you have more info, feel free to write back so we can understand better what the need is.
Good Luck!
Posted on Nov 16, 2009
Proform580xp incline goes fullup jambs ican reverse to bot reversing wires black red wires
Hi Rick, by reversing the wires, you mean reversing a 3-pin connector near 2 Triacs (Transistor looking things) that should be bolted together, near a larger transformer?
If I have the motor control board right in my mind, this board has a couple of Triacs that engage the Up/Down windings of the lift motor.
IF ONE TRIAC shorts, the machine will lift or drop constantly, pinching the lift assembly rather hard, can damage the lift gearbox, and the servicer! Other than a shorted Triac, the only other cause would be a logic high on the console cable that is plugged into the control board, at the elevation "up" line. Never dabble with powered control boards if you don't know much about them, they can bite extremely hard when energized. If you need further help, google jatinah electronics. Good Luck!
Jan 25, 2015 | Proform Exercise & Fitness
Treadmill is going backwards
if the walking belt is turning in reverse, the drive motor is also turning in reverse. Check to see if the wires from the drive motor to the motor control board have been reversed.
Was the machine recently serviced? Drive motor or motor control board replaced?
Nov 30, 2013 | Body Solid Endurance T10 Commerical...
Treadmill going backwards
Did this problem occur after this machine was serviced? Was the motor control board or the drive motor replaced?
The walking belt running in reverse indicates that either a failure of the motor control board itself, or the 2 wires from the controller to the drive motor have simply been reversed where they connect to the motor control board (controller)
Nov 30, 2013 | Proform Exercise & Fitness
Washer operates and displayes on insta wash but dose not on other options
First off, thank you for selecting Fixya as your goto place for answers. I am going to assume a few thing like the electrical cord is properly hooked up and the polarity in not reversed. Because if it is you will continue to have issues with the control board even after you replace it. Control board will be the problem here but can be caused by the polarity being reversed, but before you replace it you might want to check. I have found more board failure due to the polarity being reversed you would be shock. This is why, when reversed the power side will work for a while, but when the current changes direction or something else causes this to happen the board takes a hit, it will react confused and erratic. But yes, you will need to replace the control board to correct the problem you have today.Good Luck
Oct 22, 2011 | Maytag 24 in. MDB8751AWS Stainless Steel...
We are trying to change the thermostat, of which was brought over by the mayflower, with one of the hunter thermostats, the wiring is confusing. can you help? we have a weathertron heat pump thermostat now
red goes to r for power, yellow goes to y for outdoor contactor, green goes to g for fan,white goes to w2 or E for electric strip heat, orange goes to O or possibly B its for the reversing valve which is usually energized in cool, some systems energize this valve in heat in which case it goes on B. If you have digital stat you can use the the blue or black to connect the common terminal @ stat and the common terminal on the control board or transformer or case ground.
Jul 11, 2010 | Heating & Cooling
Can't find "Auto.Trans. Control Relay" on a 2000 Mitsubishi Mirage 1.5 liter / also maybe "Elec. Control Unit"? Vehicle isn't moving as it should, very slow in drive. The shift letters blink...
My research brought me to a schematic, which showed the location of the A/T control relay. I called the dealer to verify, using part # and location. The part is on order, I will intall it myself.
Thank You
Nov 28, 2009 | 2000 Mitsubishi Mirage
Reversing Valve not getting 24v
check for 24vac from common to orange stat wire if 24v then board bad in cooling mode you can jump the reversing valve using a jumper wire hook it from the orange wire going to coil don't need to shift in cooling only heating until you get time to fix
May 11, 2009 | Heating & Cooling
No lights or power comes on, door lock.repair man said control box so bought new one still no power,got 120 volt going in to box, (ghw9250ml0 = front load)
i think you brought the wrong board ,,i looked this up a night ago,,you need the power control board,,,im going to get the part number,,and you match it to the box or invoice,,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Aurora ASa015CD shredder
any wierd noise when it goes in reverese?
is forward dead or intermittant?
most likely if reverse is perfect but forward is dead,, your control board has blown mosfets , power drivers for forward operation
Heres a few sites that have gears n boards another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
n.
new control board needed or buy a new unit depending on cost of board.
Jun 21, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Controller port broken
Well the console might be messed up the the mother board inside of the machine is having problems then and it needs to be fixed or its getting old then.
Jun 07, 2008 | Nintendo Super NES Console
Heating & Cooling Logo
61 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
