Question about Optimus H-5210 Infra-Red Heater
The tipover switch on my H-5210 heater no longer makes contact in the closed position. Need to know where I can get a replacement switch. Switch is labeled "HI-PJ" on outside and stamped "8H22" or "BH22" on portion inside of heater housing. Thanks!
Alart light comes on why
Posted on Nov 17, 2009
Error code f51 flashing. What's wrong?
David: Try downloading this free user manual: http://laundry.manualsonline.com/manuals/mfg/miele/pw_6065.htmlk According to ApplianceHelponline.: " Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Background information:
Start position: One second after the program start, heater relay K1/1 is activated. This enables a check as to whether the contacts on heater pressure switch B1/13 have closed on switching steps 21/22 or 11/12.
Cause:
Heater relay defective; contact open.
Remedy:
Replace the heater relay.
Cause:
Heater relay solenoid defective.
Remedy:
Cause:
Connection from heater relay to electronic module open-circuited.
Remedy:
1. Check plug connections.
2. Check the connection wires for continuity.
Cause:
Heater pressure switch open- or short-circuited.
Remedy:
Replace the heater pressure switch.
Cause:
Connection from heater pressure switch to electronic open-circuited.
Remedy:
Cause:
Foreign objects in heater pressure switch.
Remedy:
Replace the heater pressure switch."
May 14, 2015 | Miele Washing Machines
What is Technical Fault 51? It appeared a few moments ago on our machine, but when I switched it off and reset the machine it worked as normal again.
F51 Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Apr 14, 2015 | Miele Washing Machines
I have a holmes heater that tipped over And now will not heat model number hrh316
The tipover safety switch worked and will now have to be reset or replaced.
Feb 20, 2015 | Heating & Cooling
How do I reset a Holmes heater, model number hrh316?
The tipover safety switch operated and will now have to be reset or replaced.
Heater will not turn on after a tip over
Some heaters are equipped with a safety switch that removes power if it is tipped. The switch may not have reset or it may be necessary to try turning the heater in various ways to get it to reset. There is a possibility that the tipover switch may have acted only once, then failed.
Oct 16, 2013 | Optimus Heating & Cooling
Heater will not turn on after tip over
shake it and see if the tilt switch resets. >>replace anti tilt switch
Oct 16, 2013 | Optimus H-5210 Infra-Red Heater
My heater does not operate. can I reset a tipover switch or internal thermal cutoff?
tipover should reset by thumping or shaking. limits sometimes have reset button pull cover an look.mostly I find limits that just dont close after tripping.the temp control is probbly a snap disc also.about $ 14 on ebay
Dec 24, 2010 | Lakewood Oil-Filled Electric Radiator...
Burner goes out after lighting and holding button for 30-45 secs.
It is usually the tipover sensor that is bad, I have had 2 of them bad right of the box. It is a black plastic peice, under the metal screen near the round know. It has 2 wires running to it, it is a saftey to shut off the heater if it tips over. to test it touch the two wires together, then try to light it, should lit no problem. Then contact manufacture for a replacement for it.
If this has been helpful, please rate the new guy :)
Contact me, If I can help you.
Sincerely,
Paul
Apr 01, 2010 | Fire Sense 01775 Patio Heater
When I close the door to the microwave, the timer is working but the microwave isn't. I believe the door latch is no longer engaging a contact point to make it work. Like the door was still open. Model #JE...
there are three switches in the door latch inside. One of them is not making contact. Remove the cover, find those switches and check for continuity with door open and door closed. If there is no continuity on one of them with neither of the door positions - rpelace that switch. GE part are expensive for no good reason, so replace with a different brand switch, with at least 15Amp rating, ie 28QBP0495
Nov 26, 2009 | Dishwashers
Intermittent heater control Marvin 2060
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
Jan 18, 2008 | Marvin 2060 Compact Heater
Optimus H-5210 Infra-Red Heater Logo
178 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
L Pfaff
L Pfaff
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
