Question about Whirlpool LEW0050P Electric Dryer
How do I take the front panel off? I am trying to take a look inside to see why I am a. getting a grinding noise b. the tumbler turns slower now that it's full power
    Scholar:
  • 86 Answers
Three screws in the back of the top panel, remove them. Pull back on the top panel and take it off. You'll need to remove the control panel. There should be two screws on both sides of panel on top. Careful. Once removed there should be two screws on the front of the dryer behind the control panel. I believe there are two clips at the bottom of the front panel, lift upwards. I should mention that this is not a fun job by yourself. You must note how the belt is put on. Your problem is probably the felt (material surrounding the drum) or the wheel bearings...good luck.
Posted on Nov 17, 2009
Grinding and grabbing in the rear of 2006 Rainer
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help link mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
CAR NOISE ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-noisesnoisy-cargrinding.html
These will help.
Thanks.
Dec 12, 2012 | 2006 Buick Rainier
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Apr 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag pye2300ay dryer grinding noise from front
You generally have to open up the cabinet from the back by unscrewing the fasteners.
Feb 06, 2009 | Maytag PYE2300AY Electric Dryer
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Loud Grinding Noise when Tumbler Rotates
Ok, these GE's sometimes have a problem with the front guides bearings going bad, and then the drum starts to eat into the top of the door hole and sides. That is probably what is making your noise. Before you spend a lot of time fixing something that cant be fixed, open the dryer door and look up in each top corner of the opening. Look to be sure the drum hasnt eaten its way through that area. If so, scrap it, because it will eat your clothes badly, and the front panels are to expensive. If not, UNPLUG YOUR MACHINE PLEASE, then standing facing the dryer, open the door, and remove the two screws that are in the top of the door housing area (not the door itself, these would be up by where I told you to look for damage). These screws hold down the top. After removing these screws, lift up on the cabinet top, and pull GENTLY towards you until the top clears the console guide posts in the top rear. After removing the top, inside the cabinet, on either side and at the top, you will see a phillips head screw that holds the front to the cabinet. Remove these screws, and fold the front towards you slowly, removing any wires that may be holding up the swing out (i.e. door switch, light wires, etc., be sure you remember the way the wires reattach). When you look at the top of where the drum rides, you will see a plastic ring with smaller like plastic flat peices that the drum rides in. More than likely, you will have to replace both parts. The ring separates in the center, and is replacable (you should only have to replace the top half). The drum guides are the smaller plastic type guides that just slide in. Reassembly is reverse. Let me know if you need further help. Jim
Nov 22, 2007 | GE DBXR463EBWW Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
277 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
