Question about Kodak Easyshare C813 Digital Camera
My camera has charged batteries and has never been dropped but it will not turn on no matter what i do
  • 262 Answers
If your using the regular AA rechargeable battery try to reverse the orientation of the battery instead of postive negative make it negative positive., now if it doesnt this way make sure the rechargeable battery that you used in your camera is the recommended battery the Ni-MH battery or the lithium., If your camera still doesnt turn On please call kodak tech support 1 800 235 6325 ext 12
Posted on Nov 16, 2009
    President:
  • 2,761 Answers
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nikon coolpix 59500
The most likely cause is a bad battery. But before you throw it out, try discharging it and then recharging it.
Probably the fastest way to discharge the battery is to turn on the flash and start taking pictures. It doesn't matter what you take pictures of, you're going to throw them away afterward. Just point the camera away from you and start clicking. Take a hundred pictures or so, or until the battery level drops below 25%, or the flash recharge time gets very long. Note the battery level, then recharge it overnight again and see what the level goes to.
Jan 17, 2014 | Nikon COOLPIX Cameras
My nikon coolpix s220 just stopped powering on. i charged the battery, but that didn't help. any suggestions?
If the camera was dropped and it does not turn on with a known GOOD battery the camera must have been damaged. When you dropped it the FIRST time and it worked you were lucky. Cameras do NOT like to be dropped.
Feb 28, 2018 | Nikon COOLPIX S220 Digital Camera
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
Camera was dropped and now won't turn on. Battery
Have you charged the battery since the drop? If not plug it in and charge it...
After that if the camera still isn't turning on then I'm sorry to say the camera is most likely busted.
But if you can get your hands on a spare battery as well give that a try.
Aug 12, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera doesnt remain on
Based on the age of the camera, it's most likely due to the battery just losing its ability to hold a charge. After several years, the battery will just cease to accept a good charge, no matter how long you leave it charging. I'd suggest a replacement battery from one of the "aftermarket" battery makers (only because they are about half the price of the original Olympus battery).
Apr 04, 2009 | Olympus Camedia Stylus 300 Digital Camera
No matter how long I charge my Kodak V1073, it just says insufficient batter when I turn it on. I'm lucky to take one picture before the battery dies.
If you just recently purchased this camera, please contact or call the Kodak help line. You may have received a battery that won't charge. Batteries need a charge at least once a month to keep them at maximum preformance. Leaving the camera battery uncharged for long periods of time can cause the battery to fail sooner than it should. If you do need to set aside your camera for a long period of time, put a full charge to it and then remove it from the camera. Most cameras (video cameras included), even if they are turned off, can trickle the charge down on your battery.
http://www.kodak.com/global/en/service/contactKodak/kodakPhoneNumbers.jhtml
Apr 02, 2009 | Kodak EasyShare V1073 Digital Camera
Camera doesn't turn on or do anything
I had a similar problem. Mt battery was dead but showed a charge when I put it in the camera. See if you can borrow a battery from another owner or camera shop and try it.
Nov 16, 2008 | Sony Alpha DSLR-A100 Digital Camera
Does the camera need to be completely charged before making pictures?
Did you mean if the camera/battery needs to be completely charged before using the it? It doesn't matter actually however, as much as possible, don't turn on the camera or remove the battery from the charger if it isn't fully charged
May 05, 2008 | Cameras
Camera Will Not Turn on
take it back to the store and confirm them
Dec 24, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Kodak Easyshare C813 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
