Hi, I am trying to fix a Kenmore Elite Dryer Quiet Pak II (110.64982300). It runs but there is no heat. I thought the problem was caused by overheating due to a blocked vent, but my efforts to date are unsuccessful. I checked the input voltage: 220v. The heating element, TCO & Thrmostat all check out; more to the point, the leads to them measure 0 volts when they should read 220v. The Thermal fuse seemed to check out, but I replaced it anyway - it reads 0 ohms. I also replaced the Thermister, which currently read about 0.5v across the contacts when the machine is running. So, I suspect maybe it is a relay? I do not know how to gwt into the console to check. Any suggestions will be greatly appreciated. Thank you, John
  • jfr1945 Nov 16, 2009
    I measured the voltage at the dryer entry terminal block and it was 220v. I need to get into the console area to go further; how do I do that?
    Thank you,
    John
  • 3,741 Answers
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
click here:--->>>How to take apart information for Kenmore dryers.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 17, 2009
  • 10,865 Answers
Hello. Thanks for choosing Fixya! You appear to have a good understanding of your electric dryer which is pretty rare. Good for you. Let me see if I can help. As you know, when there is no heat you suspect these things: 1. The power coming to the house, 2. The double pole breaker or the fuses, the heating element [have you done a continuity test on that?], 3. the thermal fuse mounted to the exhaust duct, 4. The dryer plug, dryer cord, and the terminal block inside the dryer that the wires are attached to.
Visually inspect the plug, the cord and the block, do continuity, etc. Since the dryer can still tumble on partial power it can sometimes be a challenge to spot problems in these areas so the only recourse is to change one part at a time until you have replaced the culprit.
Hope this has helped you. Keep up the good work. Regards, Joe
Posted on Nov 16, 2009
I have a kenmore elite King size Quiet Pak II dryer that won't stay on unless i hold the button down and even when i do that the dryer is not getting hot.. Any suggestions would be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite quiet pak II will come on when the start button is pushed, but as soon as I let go, the dryer goes off---HELP!
this is the answer:
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Nov 04, 2009 | Kenmore Dryers
How do I remove the bottom panel from the Kenmore Elite Quiet Pak II dryer? I need to vent the dryer from the bottom rather than from the back of the unit.
hi. thanks for the question . 2 screws on the bottom of the front panel .remove these screws . pull on panel, lift from bottom . thanks the appliance doc. please rate this answer. thanks the appliance doc
Oct 01, 2008 | Kenmore Dryers
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Quiet Pak II front-loading dryer does not heat up
First, check breaker and make sure your fuses are on... Electric dryers run on 220 volts therefore if one breaker is flipped it will turn but not heat.......... if it doesnt solve problem let me know and i will assist futher
Jan 03, 2008 | Kenmore 64902 Electric Dryer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
