Question about Cell Phones
How to adjust the time on the Clock correctly
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    What buttons change time display
    How do I set the clock?
    A5
    There are several methods to set the clock, depending on the model.
    Method 1
    Press and hold the BAND and DISPLAY buttons to display the clock
    Press and hold the BAND and DISPLAY buttons until the time display flashes
    SEARCH left to adjust the hours; right to adjust the minutes
    Press BAND button to store the time
    Method 2
    Same as Method 1, except press DISP to store the time
    Method 3
    Press ADJ
    SEARCH left or right to select clock and press ENT
    SEARCH left or right to select the hour or minute
    Turn rotary knob clockwise or counter-clockwise to set the correct time
    Press enter to store the time
    Press ADJ to return to the previous mode
    Method 4
    Press and hold the BAND and FUNCTION buttons to display the clock
    Press and hold the BAND and FUNCTION buttons until the display flashes
    Search left to adjust hours; right to adjust minutes
    Method 5
    While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
    Press the CLOCK knob to adjust the minutes
    When the CLOCK knob is released for 5 seconds, the hours will flash
    Press the CLOCK knob to adjust the hours
    When the CLOCK knob is released for 5 seconds, the time will be stored
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    go to this web site for any thing about ur stereo
    http://www.clarion.com/us/en/support/faq/Audio/index.html
    Feb 18, 2010 | Clarion Car Audio & Video
    How to set clock in 2000 GMC JIMMY
    Owners manual: 3-10:
    Setting the Clock for Systems with HR and
    MN Buttons
    Press and hold HR until the correct hour appears on the
    display. Press and hold MN until the correct minute
    appears on the display. To display the clock with the
    ignition off, press RECALL or HR/MN and the time
    will be displayed for a few seconds. There is an initial
    two-second delay before the clock goes into the
    time-set mode.
    SET Button
    Press SET. Within five seconds, press and hold the
    SEEK right arrow until the correct minute appears on
    the display. Press and hold the SEEK left arrow until the
    correct hour appears on the display.
    Nov 13, 2009 | Car Audio & Video
    Emerson smart set clocks
    Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
    Oct 26, 2008 | Emerson Smartset Clock Radio
    Sharp Atomic Clock
    I have a sharp atomic clock that once set for the exact time, after a day loses 3 hours.
    Sep 02, 2008 | Watches
    Manual for timex 609t alarm clock
    you should be able to just push the Time button (top one third from the right) and when it starts to blink, just change it like you change the alarm.
    Oct 17, 2007 | Audio Players & Recorders
    Cell Phones Logo
    23 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
