I have a saturn 2002 l200. The right high beam headlamp doesn't work. it is not the fuse or the bulb. any suggestions?
SOURCE: 99 nissan sentra headlamp - hi beam low beam issues
could be the switch. did you do anything to the switch when you changedheadlamps? maybe you put the lamp in incorrectly also did the brights work on the lamp that was "burned out"?
SOURCE: low beam headlamps not working on my 2004 armada
Did you check in the engine compartment.
If you go to autozone or advanced auto parts you can get a book for the car for about 15 bucks
SOURCE: 2002 SATURN L200 - CANNOT READ ODOMETER IN THE DARK
needs a backlight bulb this can be easily replaced by removing the cluster.
SOURCE: changing high beam and parking light bulb any
Buy, ($20 at your local auto parts place) or flip through the Chilton Manual for your car, it will show you the exact steps.
SOURCE: LOW BEAMS NOT WORKING 2002 FORD FOCUS
Hi. i recommend a thorough inspection of the wiring harness and harness connectors that led to the actual headlights. use a volt meter to test the current flow to the connectors. pull the connectors from the back side of the headlights and test all cooper contacts inside the connectors. If the wire contacts all show voltage, this will confirm a switch malfunction. it should be replaced in this case.
Now, if one or more contacts on the wires harness fail to produce any voltage, this will confirm a faulty wiring harness. replace the wiring harness in this case.
Make sure the headlight switch is in the on position when testing the wires.
The ability of the control modules to communicate through the serial data circuit
The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
The
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
