Question about Riso RZ220 Duplicator
Riso RZ220 paper is jamming when feeding. Paper
Riso RZ220 paper is jamming when feeding. Paper starts feeding then flutters and occassionally feeds thru.
  • da82190 Nov 16, 2009
    Thanks for the help. I tried everything you suggested with no results. It appears as though it is an issue with a roller or blockage. Sometimes the paper makes it thru and most of the time it starts feeding and starts fluttering then goes thru and then we get a jam error.
  • 3,741 Answers
Its the issue of gears that move the roller that rolls in and feeds the paper in.its a very common problem.
simply dissemble the gears clean them or just get the printer fully serviced.it will be just fine.
nothing much to worry.servicing clears this problem easily.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 17, 2009
    Brigadier General:
  • 3,513 Answers
Hi
Please try the following to clear this paper jamming scenario.Switch off/on the machine holding down the reset key? Remove the power cable from power source for few minutes. If its a temporary software issue it will get sorted out. Pull out master roll and reinsert it. Check wether you have properly inserted the master disposal tray or not. If these don't work ask for further assistance.
Thanks for contacting fixya.com
Posted on Nov 16, 2009
Re; fr3950EP machine, I moved the paper sideways 10mm, light gone out and machine won't start again, display panel just says check paper feed area
Pls, I have risograph FR3950EP
I need the full drum unit, computer interface card, master and inks of different colours. Kindly help me out. I am in Nigeria.email: engrmoob@yahoo.co.uk
Nov 26, 2011 | Riso RZ220 Duplicator
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
Im having problems with my Riso RZ300. error A-06 and ive tried to clean the paper tray it keeps on flashing the same error. Thanks for your attention David
There should be a numeric extension to the error. Ist it this error A06-403? This means:
Error type A06: Check paper feed tray Error point 403: Either the upper or lower safety switch of the paper-feed-tray is OFF.
Hint: Check the mentioned switches.
Oct 10, 2010 | Riso RZ220 Duplicator
Problema para Riso - Duplicadora RZ220 Copiadora Error message A-06-403 Mensaje de error A-06-403
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
Aug 09, 2010 | Riso RZ220 Duplicator
Risograph rz220 paper not feeding
If paper is fluttering while feeding, what is actually happening is that the pressure solenoid doesn't activate. This is caused by paper dust on the paper sensor.
Take the drum out...notice the white guide roller on the left side inside the machine...it is held on with a white e-clip that can be removed by hand. The paper sensor sits just behind this roller. Remove with a phillips screwdriver and clean the sensor.
Feb 03, 2010 | Riso RZ220 Duplicator
I have a Risograph rz220 that jams every time i run paper thru it. the paper feeds then flutters the fees on thru but jam light comes on each time and have to re-start it.
There is likely a piece of paper on the roller or gear that is still in there causing a jam. I would dismantle as much as possible to find the jam.
Nov 20, 2009 | Office Equipment & Supplies
Paper not feeding. The drum is spinning LCD screen read idling
If your Riso is idling it is probably due to it trying to get ink into the drum.
Let it finish the idling may take 3 to 5 min, then make sure there is ink up to the spout of ink tube or replace ink tube.
If you press the astrex button it can give code which you can look up in the book.please tell us the model of riso.
Apr 05, 2009 | Riso RZ220 Duplicator
Paper feeding problems Riso TR1510
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
Riso rc6300 registration not correct
ou need to either advance (paper feeds quicker) or elay paper feed there has to be a registration adjustment
It can be as simple as adjustment of the feed wheels or some type of delay in the drum rotation
take alcohol and clean the feed rollers they may be slipping
Dec 27, 2008 | Riso RZ220 Duplicator
102 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
