No reports i can't get our HP ColorLaser Jet 2840 printer to print a report after every fax.
  • 589 Answers
This can be set in "fax parameters". Do you have the manual?
Posted on Jan 09, 2008
How to reset supplies on HP 2840 laserjet?
"Would like report of supplies from 2840 laserjet. How to get it to show report"
Select 'Menu" button, then select "Reports", then select "Supplies Report".
This will print the status of the four toner cartridges and the drum.
It doesn't make sense to reset toner cartridges UNLESS you refill them
first. On the HP 2840 each cartridge/drum contains a chip that measures
the life of the unit.
You can purchase toner/chip combinations online cheaper than new
cartridges. I also purchase drum chips to extend the use of my drum
until print quality actually starts to deteriorate.
I use both of these methods to save money on supplies - buy toner and
toner chips, buy drum chip to get full use of drum unit.
Hope this helps.
Mar 19, 2012 | HP LaserJet 2840 Printer
How do I print a communication report (lists all communication errors receive / send) for the day ?
a config report should do this
hit menu
go to information
select configuration report and print it
there may also be a fax report or jet direct report on its own
Jan 19, 2011 | HP LaserJet M3035 MFP Printer
Image on fax send report is set to off. Will not send fax
1> Press the wrench/tool mark (SETUP) button on the printer.
2> Go to 'Print Report'
3> Go to 'Image On Fax Send Report' and use the arrow key on the front panel to change it to ON and select/press OK tio save.
Jul 15, 2010 | HP J4680 Office Jet All-In-One Printer
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I print a report of a fax confirmation
Found the manual for this machine here:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00292207/c00292207.pdf
Refer to page 188 of this manual for printing the fax activity log (last 40 faxes).
Hope this helps.
Jan 13, 2010 | HP LaserJet 2840 All-In-One Printer
Fax reports no longer printing.
check the settings to ensure that ist is actually on. You may not have gone in there and changed them, but they will do it on their every now and again
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Mar 25, 2009 | HP LaserJet 4 plus Printer
I CANNOT RECEIVE A FAX CONFIRMATION...HOW I CAN CONFIGURE MY FAX. MY MODEL IS HP LASER JET 1522nf. THANK'S FOR YOUR HELP.
If you look at the manual, it explains this, but for simplicity...
You need to turn on reports for faxes.
hit settings
go to report
select print reports then select all faxes
Falstagg
Sep 20, 2008 | HP Office Equipment & Supplies
How to control/suppress transmission(fax) report in HP office jet 6110
I assume that the fax report is printing on every fax and you don't wish to see it?
In your setup menu if you go to advanced fax setup and then the first option will be automatic reports setup. Hit the okay button and then you can choose when the report will print out. In your case you would scroll to the last option which is 'off'. The reports should no longer print. If you did want to see when there was an error you can set it to error only there as well.
Feb 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP COLOR LASERJET 2840
scan the report you are putting in for fax. give a print command for the scanned image/document after the scanned article is saved in the system
Sep 18, 2007 | HP LaserJet 2840 All-In-One Printer
51 people viewed this question
k24674
jasbo
jasbo
