Question about Electrical Supplies
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
  • 37 Answers
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Posted on Nov 22, 2009
Model 253707041901 magneto gap spark plug gap are needed
Check with the spark plug manufactuer's online catalogue for the correct gap.
The contact breaker gap is 20 thou.
May 12, 2017 | Garden
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
1978 Honda twin star doesn't have spark
It is called Hot coil trouble, but coil doesn't necesarlly need to be hot to fail. It might be hot internally and cold to the touch.
This symptom is caused by excesive resistance on the high voltage side of the coil. When the coil works harder trying to send the current through a high resistance path to the spark plug, it gets hot and quits. There must be a bad connection or a damaged conductor between the coil and the spark plug's ground contact at the screw threads.. Even a too large spark plug's gap could cause enough resitance to cause coil failure. Corroded terminals o broken HT spark plug wire can cause it too. Have you recently replaced something in the high voltage circuit? Check it out. Good luck!
Nov 09, 2013 | Honda Cm Cm185 Twinstar Cm185t Generator...
V65 honda engine miss at high rpm
ignition system ...try new or hotter spark plug set gap to .45
Apr 04, 2013 | Honda 84 V65 Magna Vf1100c Stator...
220 volt outlet
you can find it in electrical store.
Jul 05, 2009 | Electrical Supplies
On and off switch Honda ES3500
Locate the wire to the kill switch and inspect for disconnected or damaged.
If not...
locate its connection (plug) disconnect it, start the engine, insert a small screw driver into the plug that leads into the engine assy. and ground it to the engine to check that it stops the engine. If so the switch is not grounded or faulty.
If not...
That circuit is damaged inside the housing.
Those switches operate by grounding the signal to the coil to stop the spark.
On position = open/not grounded
Off position = closed/grounded
I hope this helps...Good luck
Aduz
Mar 15, 2009 | Electrical Supplies
Week spark on honda 5.5hp gx160
Hi
I suppose is 4 stroke engine.Before adjusting the breaker points gap at .020 check if the breaker points are burned.Also check the condenser(change it).Change the spark plug with a new one with the same heat range.The plug gap is .030.
best regards savumihai71
Feb 12, 2009 | Electrical Supplies
Gas Generator SPark Problem
Hi jeff best regards savumihai7
Inside of the rubber boot,at the plug wire terminal there is a spring making connection with the ignition coil(under the flyweel).Check the connection first.Try if there is a spark.If there is not,. remove the flyweel.You will see the coil and ignition wires.Check them by mearurement.Remove the spring and the cover and under it there are breaker points(they has not to be burned).The excentric on the crankshaft open the breaker points(gap) to have spark.Also clean the armature and the magnets from flyweel.Let me know.
Dec 15, 2008 | Electrical Supplies
I need a carb for a es3500 honda
Good place for honda parts is http://www.jackssmallengines.com/index.html. I would try to repair the carb first using a kit containing gaskets and needle. enjoy
Nov 27, 2008 | Electrical Supplies
Ihave a honda ganerater MODEL#ES3500 and dont know were the battery goes.
The battery '+' attaches directly to the starter and the '-' cable is grounded to the frame/block.
Nov 03, 2008 | Honda Electrical Supplies
Electrical Supplies Logo
505 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
