Question about D-Link AirPlusG DI-524UP Wireless Router
Cisco VPN doesnt get connected through DI-524UP router. Worked fine until recently for both the laptops we use. Log indicates Receive: Purging stale cached fragment(s). Direct connected on the Motorola surfboard there is no problem. Detailed log: ... 32 21:25:05.140 11/16/09 Sev=Info/4 CM/0x6310000E Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system 33 21:25:05.312 11/16/09 Sev=Info/5 IKE/0x6300005E Client sending a firewall request to concentrator 34 21:25:05.312 11/16/09 Sev=Info/5 IKE/0x6300005D Firewall Policy: Product=Cisco Systems Integrated Client Firewall, Capability= (Centralized Protection Policy). 35 21:25:05.312 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to *** 36 21:25:06.234 11/16/09 Sev=Info/4 IPSEC/0x6370001A Receive: Purging stale cached fragment(s). (Peer=*** FragId=25404) 37 21:25:10.734 11/16/09 Sev=Info/4 IKE/0x63000021 Retransmitting last packet! 38 21:25:10.734 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(Retransmission) to *** 39 21:25:11.234 11/16/09 Sev=Info/4 IPSEC/0x6370001A Receive: Purging stale cached fragment(s). (Peer=*** FragId=22876) 40 21:25:15.234 11/16/09 Sev=Info/6 IKE/0x63000055 Sent a keepalive on the IPSec SA 41 21:25:15.734 11/16/09 Sev=Info/4 IKE/0x63000021 Retransmitting last packet! 42 21:25:15.734 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(Retransmission) to *** 43 21:25:16.234 11/16/09 Sev=Info/4 IPSEC/0x6370001A Receive: Purging stale cached fragment(s). (Peer=*** FragId=49756) 44 21:25:20.734 11/16/09 Sev=Info/4 IKE/0x63000021 Retransmitting last packet! 45 21:25:20.734 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(Retransmission) to *** 46 21:25:21.234 11/16/09 Sev=Info/4 IPSEC/0x6370001A Receive: Purging stale cached fragment(s). (Peer=*** FragId=31754) 47 21:25:25.234 11/16/09 Sev=Info/6 IKE/0x63000055 Sent a keepalive on the IPSec SA 48 21:25:25.734 11/16/09 Sev=Info/4 IKE/0x6300002D Phase-2 retransmission count exceeded: MsgID=FFBE549D 49 21:25:25.734 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to *** 50 21:25:25.734 11/16/09 Sev=Info/6 IKE/0x6300003D Sending DPD request to ***, our seq# = 1768728419 51 21:25:25.734 11/16/09 Sev=Info/4 IKE/0x63000017 Marking IKE SA for deletion (I_Cookie=C2F56E4D7C527ED7 R_Cookie=DFFB6101379DE1A5) reason = DEL_REASON_IKE_NEG_FAILED 52 21:25:25.734 11/16/09 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to *** 53 21:25:28.734 11/16/09 Sev=Info/4 IKE/0x6300004B Discarding IKE SA negotiation (I_Cookie=C2F56E4D7C527ED7 R_Cookie=DFFB6101379DE1A5) reason = DEL_REASON_IKE_NEG_FAILED 54 21:25:28.734 11/16/09 Sev=Info/4 CM/0x6310000F Phase 1 SA deleted before Mode Config is completed cause by "DEL_REASON_IKE_NEG_FAILED". 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system 55 21:25:28.734 11/16/09 Sev=Info/5 CM/0x63100025 Initializing CVPNDrv 56 21:25:28.734 11/16/09 Sev=Info/6 CM/0x63100046 Set tunnel established flag in registry to 0. 57 21:25:28.734 11/16/09 Sev=Info/4 IKE/0x63000001 IKE received signal to terminate VPN connection 58 21:25:29.234 11/16/09 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 59 21:25:29.234 11/16/09 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 60 21:25:29.234 11/16/09 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 61 21:25:29.234 11/16/09 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped
Cisco VPN
Upgrade your router to the latest firmware. You can download firmware at http://www.dlink.com.au/tech/ .
Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Configuring PC running VPN Client Software:
Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
Step 3 Configure Cisco VPN Client - Connection Properties.
Step 4 Check Enable Transparent Tunneling.
Step 5 Allow IPSec over UDP ( NAT/PAT).
Configuring Router using the Web-based configuration:
Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
Step 4 Click Apply.
Step 5 Click on the Virtual Servers button on the Advanced tab.
Step 6 Enable IPSec from the list and configure as follows:
Private IP: IP Address of the PC running Cisco VPN Client
Protocol: UDP
Private Port: 500
Public Port: 500
Schedule: Always.
Step 7 Click Apply and then Continue.
Step 8 Enable PPTP from the list and configure as follows:
Protocol: TCP
Private Port: 1723
Public Port: 1723
Schedule: Always.
Step 9 Click Apply and then Continue.
http://www.dlink.com.au/tech/default.asp?model=DI-524UP
Posted on Nov 23, 2009
  • mlynski Jan 22, 2011
    One should install firmware 1.01.08 from the pagehttp://dlink.ua/files/products/ftp/pub/R... It is much worse than the version 1.06 but a VPN works
The solution for me was change the user account to connect to the ADSL provider. There are two ways to connect to my ADSL provider (GVT Brazil): thru firewall by using the account turbonet@fw.turbonet and without firewall by using turbonet@turbonet. When I changed from turbonet@fw.turbonet to turbonet@turbonet it started working fine. I conclude that the firewall was blocking the Cisco VPN. It was not needed to change MTU, disable SPI mode, disable Windows 7 firewall, enable Virtual servers, etc. I am using DI-524 UP with firmware 1.06. The VPN client is version 5.0. The modem ADSL is Siemens SpeadStream 4200 in bridge mode.
Posted on Jan 29, 2011
    Guru:
  • 1,738 Answers
Try upluging it.
Posted on Nov 16, 2009
Belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
Jun 08, 2012 | Belkin Connect N150 Wireless Router...
I can access internet but cannot get in via cisco vpn(intermitent
Look at the number of users you have enabled in the router. If you only have 3 and you are using 4 computers, you could be getting the kind of behavior you are describing based on how many computers you have connected at the time.
Jun 18, 2009 | Belkin (F5D5231-4) Router
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
VPN connection issues
check if you can enable "VPN pass-through" on your home router.
try diabling its security features (firewall) one at a time and try afterwards.
last option perhaps try upgrading to the 5.06 version of the vpn client.
Apr 06, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
D-Link AirPlusG DI-524UP Wireless Router Logo
1,710 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
