Question about Dual XDVD-1002CM Car DVD Player
Dual xdvd1002cm My image just recently got inverted. is there a way fo fix this?
0 characters
1 Points
First thing to try is to shine a light on it to see if there is an image that is there that you can see. If there is, the back light or the inverter is out. Let us know,
Jun 05, 2014 | Dual Car Video Players
My touch screen works when you touch it: but the outer screen is black off. when i put a UV light up to the screen i can see the back buttons and i can touch them. how can i fix my screen what part do i...
Looks like ur inverter, thats lights up ur LCD screen don't work!
Either ur inverter is disconnected or capacitors in the inverter is broken.
better bring that unit to ur nearest service center to fix on that.
Dec 01, 2010 | Pioneer AVIC-N1 Car DVD Player
Jensen vm 9410
some of the newer dvd's are made double layer and recently they've been working on triple layer dvd's. basically a single layer dvd holds 5gb of information, a dual can hold 10gb and a triple can hold 15gb (those are approximates). by making it more layers, they can put the fullscreen and the widescreen edition on the same movie disc. some of the 'lower end' dvd players don't have the capabilities to play these dual or triple layer discs.
Sep 21, 2009 | Jensen VM9410 Car DVD Player
Eonon E1023 cant view dvd or tv
You need to connect the wire marked ' brake cable' to the ground wire. Just squeeze it in and then the picture will come on fine.
Mar 12, 2009 | Car Video Players
Dual XDVD710
We can fix that<
send it to ALLTRONICS $125.00 TO repair it and we will ship it back for free.
Sep 28, 2008 | Dual XDVD8181 Car Video Player
Dual Xdvd710 Cd ejecting
i have the same problem, the spring goes around that shaft you see, but the plastic that holds all of the spring mechanism together is really fragile ive tried fixin mine several times but have failed all times i finally just gave up, i tried calling the duel company but they basicly told me i am on my own, so the only thing i can tell ya is do waht i did ,USE IT FOR TARGET PRACTICE!!, thats all this radio is good for
Jun 10, 2008 | Car Video Players
Dual XDVD 700 Blank Screen
Take and bench test it. Pioneer brand do that when the ribbon cable is cracked. It is the one that get drag in and out during open and close. Open it up and check that. Goodluck.
Feb 05, 2008 | Dual XDVD8181 Car Video Player
just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Jan 08, 2008 | Dual XDVD8181 Car Video Player
Open Questions:
Dual XDVD-1002CM Car DVD Player Logo
23 people viewed this question
Top Dual Car Video Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
Brian Hogue
Level 1 Expert
Are you a Dual Car Video Player Expert? Answer questions, earn points and help others
