Question about Microsoft Windows XP Home Edition
Ring sound windows home edition xp
Hi
I keep on hearing a ringing sound coming from my pc have you any ideas of
what it may be.
  • 3 more comments
  • gilly42 Jan 09, 2008
    Thanks for replying to me but this hard drive was only replaced around the 12th December as I had a new pc in August and the hard drive was faulty ,this was replaced with a new one.
    My pc is brand new it is only 4 months old.
  • gilly42 Jan 10, 2008
    I have gone into the control panel and gone into sounds and went through them to listen to each of them
    There is an open program sound and listening to this sound is the sound that it makes.
    Gillian
    Hi
    Yes the sound is spasmodic and random and it is only online, but this sound it not to let me know i have email as I have a notifier that comes on my screen to advise me of email.
    I dont have a chat messeger set up either.
    gillian
  • gilly42 Jan 11, 2008
    Hi
    I have checked the event viewer and there is alot of yellow warning signs Minstaller what does this mean.
  • catkimball Feb 22, 2009
    Mine I would describe as a rapid, repetitive "dinging" sound. Almost like when a key on the keyboard is stuck or held down, but with more of a "chime" to it. It happens randomly, sometimes when I'm in bed, asleep, and it wakes me up. I thought it was the keyboard (cordless) so I took the batteries out, but it still happened. I cleaned the entire computer, inside and out, but still randomly occurs. Any thoughts?
    Scholar:
  • 146 Answers
Could be either the cooling fan or the hard drive on it's way out, in either case, it's a good idea to back up your hard drive before any problem causes you to lose data.
Posted on Jan 09, 2008
  • 3 more comments
  • martin hogg Jan 10, 2008
    it helps to know...thanks. Without hearing the noise it's difficult to be certain obviously, as computers contain no moving parts except for the fan or fans ( one for the processor and one for the power unit ) and the hard drive, a mechanical noise has to come from one of them....unless it's not a mechanical noise ! does it sound like an electronic or phone type noise ?
    mmm ...without labouring the point...does the sound repeat on a regular basis ie every 5 seconds, 10 seconds etc. or is it spasmodic and completely random ?
    If it only does it when you are on line for example, it could be to announce the arrival of mail or on-line chat perhaps ?
    ( if enabled )
    You could bring up task manager, ( click ctrl + alt and delete ) check the tabs applications, processes, performance to see where the activity is taking place when this noise happens.
  • martin hogg Jan 11, 2008
    normally when a pc beeps, it is on bootup and the series of beeps and timing indicates a problem, however yours is different and has me scratching my head.........the only thing I would suggest finally ( in addition to task manager as in previous post ) is under "administrative tools" if you click on"event viewer" then "application" you will see a list of events with precise times for each logged event, some may have hazard signs, so what I suggest is that you note the precise time of the beeps 2 or 3 then compare those with the event log and see if any correspond, if they do, you would be advised to make a note of or print these and get some IT person to check out your machine and give them the details from the event log. Sorry, but I really think we have reached the limit of what we can do remotely.
    Good luck !
    Finally...One more thing you can try !
    1. Right-click My Computer and select Manage.
    2. Expand System Tools and select Device Manager.
    3. From the View menu, select Show hidden devices.
    4. Expand Non-Plug and Play Drivers.
    5. Right-click Beep, and select Properties.
    6. Select the Drivers tab.
    7. Click Stop. You can also change the start-up type to Disabled so the beep service never starts.
    OR
    In Windows 2k/XP there is a way to disable the beep, go into device manager, select the "Show hidden devices" option, go to "non plug and play device" find that device named "Beep" and set it to disabled.
  • martin hogg Jan 12, 2008
    I have checked on Google, it seems to be an excellent application and I have listed some features of minstaller below for you, however you need to check the times of these events against your mystery beep as I said previously, if they correspond then you could stop that application from running and see if the beep stops, if not, then you would be best to follow my other post and disable the beep.
    Here are some key features of "mInstaller":
    · Unique ratio of number of program functions and its size.
    · Small program size (47KB).
    · Small size of installing module (12-13KB).
    · Strong ZIP-like compression. It is even better on some data.
    · Small un-installing module (4KB).
    · The program is absolutely FREE for any purpose.
    · Suitable comprehensible program interface and reference. The program is really easy to use.
    · Multilingual program interface (Russian and English).
    · Ability to create multilingual installer and uninstaller.
    · Support of displaying the license while installing.
    · Support of alternative program interface. It is painted with user colors.
    · (ability to paint program as you want).
    · Support
    of creation of uninstaller (built-in uninstalling module).
    · Support of MS Windows XP interface themes.
    · Ability to set the producer name to show it separately in the installing dialog.
    · Simple way to give all the files for installing by only directory name.
    · Ability to set the program name for displaying separately while installing.
    · Ability to change the built-in icon of installer.
    · The program and created installers work even when screen is small than needed (scrolling is used).
    · Ability to create shortcuts for installed files in any place of the system.
    · (desktop, start menu, programs menu, autorun menu, quick launch panel, send-to menu).
    · The user during installation can choose which shortcuts to create.
    · (but some shortcuts can be mandatory, this is defined at project creation time).
    · Ability to create folders (groups, submenus) in programs menu.
    · Ability to set a password for created installer. Anyone can`t install your program without that password.
    · Ability to set the default install path (support of environment variables like %ProgramFiles%).
    · Any amount of files/programs/folders can be automatically started after installing.
    · The program supports project files for more convenient periodic work.
    · There is no restrictions on number of the files/folders to install.
    · mInstaller works under all versions of OS MS Windows, as from Windows98 (under Win95 it possibly works too).
    · mInstaller works under OS of family Linux through program Wine.
    · mInstaller works under OS ReactOS (as from version 0.3.0).
    · The program is always in developing to fully satisfy the user.
    · Constant support through the program site and email.
    · It is ideal for small programs, but it will useful for large projects too.
    · Encryption of all data.
    What's New in This Release:
    · New program icons.
    · Now there is only version of mInstaller (full&lite are merged).
    · Uninstaller erases all the files in program directory.
Free download windows xp home edition
format it and install windows vista or later
Jan 21, 2014 | Computers & Internet
I cannot play a sound because i don't have a sound
Click on the links below if your computer has that particular operating system on it.
Microsoft Windows 2000 s.gif » Microsoft Windows XP s.gif » Microsoft Windows XP Home Edition s.gif » Microsoft Windows XP Media Center s.gif » Microsoft Windows XP Professional s.gif » Microsoft Windows XP Tablet PC Edition
Jun 06, 2010 | HP Compaq nc6000 Notebook
I've had my phone for about 15 months. It still works people can ring me and I can call out. However, I have totally lost sound. The keypad sounds and ringtone do not work and I can not hear anyone on...
Its internal speaker (not the earpiece speaker) is dead. I dropped a phone handset of mine and the little speaker snapped off of the circuit board internally.
You don't say if the unit (model ???) has a base station or is wireless. My base station would still ring.
Jan 26, 2010 | Samsung 500w Rrss Rear Reflecting Surround...
I have Windows xp and gigaware usb stereo headset w/mic. The headset works, at least the mic and the speakers work. I can't get it to work with google voice. When I make a call through my laptop, the call...
First of all you installed Sound driver.
Than go to control panel and click on sounds and audio devices.
Than click on voice and reset it to default and restart your system.
I hop its working fine.
Regard,
Abhay Singh
Dec 09, 2009 | Microsoft Windows XP Home Edition
Telephone ringing sound periodically coming from pc speakers
My guess is you are hearing a telephone ring .wav file that is being played as an alert for some software application you have installed on your system. Perhaps an email account is trying to let you know that new mail has arrived, or some such. Are you getting any kind of pop up notification window in the lower right portion of the screen when the ringing sound is played? If so, find out what program is notifying you, and go to the options/preferences settings for that program and you will probably find a sound alert option that can be turned off. Southwest airlines has a ding feature like this that alerts people when a flight they have set to search on is available, for example.
The only other place I can think to look is in your event viewer, (Rt.click My computer,choose Manage). Perhaps you'll see a corresponding entry under applications, but this seems unlikely to me.
You need to figure out which program is alerting you.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Computers & Internet
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
Hallow Dear,
Please use this link to download Drivers for your PC (20M)
XP/Vista - ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Operating Systems
Microsoft Windows XP Media Center Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Ultimate 64 Edition
This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
(I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Windows xp home edition service pack 2
Legally, well purchase the software. But if you do that I wouldn't buy Xp Home Edition I would go with XP Pro.
On the other end of things check piratebay.com or other torrent sites. You may be able to find just the product key or a version where you do not need one or that comes cracked.
Hope that helps.
Oct 23, 2008 | Microsoft Windows Xp Home Edition Sp2...
Product key
If you have the genuine office 2003 cd. There would be a digital number on the inner ring of the cd. You can call up microsoft at 1-800-642-7676, give them the digital number and they would generate the product key for you.
Thanks
Proton
Aug 03, 2008 | Microsoft Windows Xp Home Edition English...
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Microsoft Windows XP Home Edition Logo
365 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
