Question about Audiovox Bosch 718 World Cellular Phone
My washer does not do the final spin and needs to be started again through the whole cycle - I have reduced the amount of soap used
I have a Samsung eco bubble WF1804WPU model that started showing the error message SUD. Any time it happens the machine stops washing as if paused and I have to press the pause button twice for it to start...
The SUD error indicates an excessive amount of soap suds in the wash. It will be difficult for the machine to rinse / spin all the soap out during the cycle, and may need to be run thru the cycle again (do not add any more detergent!).
Remedy:
Stop using regular detergents! Front loaders specifically call for "HE" (High Efficiency) detergents as they require less detergent and clean better with the reduced amount of water in these machines. Look for your favorite brand and select the one with the distinctive HE logo show below:
Use only the amount as directed on the bottle - do not use too much. Clothes should come out clean and soap free - and the SUD error should no longer appear - if it continues - double check the amount of detergent you're using as it is probably still too much.
Jan 30, 2015 | Samsung Washing Machines
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
More Here
Dec 29, 2010 | Whirlpool Washing Machines
Would you know why a washing machine stop in the
How much soap are you using? These newer models only use a small amount of water. You go adding a ton of detergent and that washer is gonna worry itself to death trying to get rid of excessive suds.
Jul 06, 2010 | Westinghouse Washing Machines
My LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Jun 30, 2010 | LG Washing Machines
Screen flashing "LE" and will not finish spin cycle?
1) Musty Odor
front door gasket
May 24, 2010 | LG WM-2277HW Front Load Washer
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Audiovox Bosch 718 World Cellular Phone Logo
23 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
