I have a HL-P6163W Samsung and I need to replace the color wheel. Where is it located in the set and how do I remove the old one and install the new one. I have replaced the light. Thanks for the help
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If the color wheel is bad you should be able to remove the lamp and see it---the lamp faces it---it is a small round wheel with colored segments--if any are missing or gone it is your problem.
The wheel is located inside the set's optical light engine--you have to remove the engine to replace it--there are several sites on the internet that have printed and VIDEO instructions for the replacement of the wheel--takes less than a hour to do--
If you Google the model number on the set you should be able to find the part number----if not let me know and I will try to find it for you.
Most of the color wheels for these range in price from 90-140 dollars and there are a lot of sellers on Ebay who sell them.
Let me know if you have questions or need help--I am here to help people.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 16, 2009
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Thanks.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
Samsung Big screen mod. HL-P6163W made load pop, then buzzing sound with screen going to black and white. Make buzzing sound and no picture when turned back on?
This set has a problem with the color wheel falling apart, which if one of the segments should fly off while the set was on it may sound like a loud pop, and the buzzing sound could be mechanical in nature with the wheel being off balance. If smoke appeared after the loud pop, then it could be a capacitor blowing in the power or video circuits. This model uses two different types of Color Wheel assemblies, either an L3 or a L6 and it would be listed on a white label on the Light Engines metal frame. Hope your solution is this easy.
Bill
Mar 08, 2011 | Samsung HL-P6163W 61" TV
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
I changed the color wheel and the blub the picture is fuzzy and the colors look out of place a lot of green need help!!!!!!! hlp6163w
Are you sure that you have the good color wheel for the LIGHT ENGINE install in your tv. Samsung use different version of light engine who had their own color wheel.
Apr 27, 2010 | Samsung HL-P6163W 61" TV
Replaced color wheel on my Samsung 61" HL-P6163W. Colors on the TV are off. How do I reset this? I've seen posts regarding a jumper wire. Does this apply to my model? If so, where is this jumper wire?...
did u not pull the jumper if u put in a new air bearing color wheel it spins much faster u have too pull the jumper on the board beside the little fan its black just pull straight out its black little plastic thing look on the silver slotted case youll see two little square opening one has the black jumper right there pull it out did mine already see ya
Dec 29, 2009 | Samsung HL-P6163W 61" TV
How to replace faulty lamp cooling fan on HL-P6163W TV
A more likely candidate is the color wheel,unless your sure it's the fan
Dec 01, 2009 | Samsung HL-P6163W 61" TV
I need instructions on installing a color wheel
i found a step by step video on you tube it was great
May 05, 2009 | Samsung HL-P6163W 61" TV
How to install a color wheel on a samsung hl-p6163w
To install a color wheel on HL-P6163w just: unplug set and remove rear cover. Remove the screws holding the plastic cover over the audio/video jacks. Remove the screws holding the large metal box (digital module) in place. Disconnect the plugs on right side of the digital module and disconnect the plugs remaining in your way of removing light engine, located on the metal sheet on right side of set. Remove the two screws that hold the light engine in place and slide towards you carefully so as to not stretch any remaining wires. Black, plastic cover that shields the color wheel has three screws that hold it in place, and you need a long screwdriver to reach them(matgnetic tip if possible). Once you remove the cover you will see the color wheel and the screws holding it in place. There are two plug connectors attaching it to the shielded DMD module and make sure to put the ribbon connector back on the right way. It has contacts on one side only. Carefully reconnect all plugs and if the plugs are identical you need not worry in which order you connect them. Make sure that you plug all connectors in and engage safety switch for lamp cover to test your work. It should be fairly easy but a bit time consuming for your first round with light engine servicing. Keep your distance from the ballast that runs the lamp while testing as it can pack a powerful punch. Good luck, Russmann.
May 05, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
