Question about Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
  • 571 Answers
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Posted on Dec 05, 2009
My Canon AE-1 Program will take a picture when cocking back the film advance lever, the shutter button does not have a roll in my camera what so ever.
Sounds as if the interlock between film advance and shutter mechanism may need looking at. Repair shop job, I'm afraid.
Dec 30, 2015 | Canon Photography
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
My shutter release button is not working, instead the shutter is being released when I use the film advance lever.
Your camera has a bad magnet in the body.
Repairs will cost more than probably what you paid for it; I'd suggest getting a replacement (I got a Canon AE-1 Program for $40 on craigslist, ebay has good prices)
Nov 11, 2009 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Just purchased from an auction. the film advance
The first to check is the battery condition. Press the battery check button on the top cover and see where the meter needle rests in the VF. If the needle is above 5.6, battery is getting weak and it will cause irratic shutter release or no release. It's time to change the battery. If needle is below 5.6, then you have magnet problem or other fault. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 31, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AT-1 (Similar AE-1) Shutter Fires Upon Advancing Film Lever
No need to look at the schematics. It only will give you a little headache. Replace Shutter release magnet (MG#3). While winding stage the Mg#3 suppose to catch the lever and any dirt or particle may prevent it. Clean it and it shoud take care of the problem. Good Luck -James. For further assistance email, go to www.camerarepairjapan.com
Dec 20, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon EOS-AE-1 35mm SLR Camera Logo
1,718 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
