Question about Kenmore Washing Machines
Groaning sounds when draining
When the washer goes through drain cycles, it makes this extremely loud groaning sound that can be heard for miles.
  • 6,784 Answers
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. This actual section of the pump is not designed to be repaired. You will need to replace the entire pump device, asap. Once replaced, the unit will operate properly, and without the noise.
Posted on Nov 16, 2009
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Posted on Jul 05, 2008
Beko WME8772W washer not working
clean the filter first
look in the pump for any bits in it
Feb 06, 2014 | Washing Machines
Short cycling and groaning
Sounds like it is water bound. Power down, drain the tank, restart and see if the problem goes away. If it does it indicates a problem with the air volume control.
Sep 10, 2013 | Wel - Bilt Plumbing
I have the same groaning noise with my dish washer GSD2200G02WW
Remove both spray arms, and try a cycle with the washer empty.
If the noise changes or dissapears - replace one spray arm and try again. Replace the spray arm that creates the noise.
If there is no change, then replace the drain pump.
May 02, 2010 | Dishwashers
Won't drain. Won't spin.
Sounds like there's a blockage in the drain hose, or the pump. There could be a coin jamming the pump impeller. If the clothes are wet it's got to be a drainage problem...Good luck....Nomess
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water does not drain from machine at end of cycle
it sounds like the out flow is blocked some where on the front of your machine normally down the bottom there is a door open it behind should be a tap/plug type of thing turn it but put something underneath to catch the water this takes time when done take the plug out all the way have a look at the fan behind it will probably be blocked
Aug 21, 2009 | Asko D1716 Built-in Dishwasher
2002 buick rendezvous groans when turning
The fluid in the versa trak AWD in the rear is old and needs to be drained and refilled. After you drain and refill it, make a bunch of sharp left and right hand turns, then drive it for 10 minutes. Drain and refill it for the second time and problem solved. Use only versa trak fluid available at any GM dealership. There is TSB on this now at the Buick dealership.
Jul 22, 2009 | 2002 Buick Rendezvous
96 Grand Am Groaning
Sounds like the power steering pump failing. If it seems to be worse when you turn the wheel at a stop, it is time for a new p/s pump.
Jun 26, 2009 | 1996 Pontiac Grand Am
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
