Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My memory is filling up in the media section, but there are no images to display and the icons cannot be opened, deleted or transfered any where.
Your phone memory almost full pleas delate some datahttps://www.fixya.com/images/misc/pqp_man_np.png
This means that you have filled up your phone with data to it's full capacity - You might have too many videos, pictures, music, text, or other media on your phone. You can free up space by deleting these files. If you want to keep the data, you can transfer it to your computer before deleting it off your phone.
Mar 12, 2011 | Computers & Internet
How to delete pictures?
To delete the images from the Camera, press the Play button on the Camera to view the images. Display the images which you want to delete and press the DELETE button (Recycle Bin icon) located below the lower left of the Control buttons.
To delete multiple images, slide the index lever and select with the control buttons.
While the index screen is displayed, press the Delete button and select the images with the control buttons and select Enter button. Now, select the images which you want to delete and press the Enter button to display the Delete icon on the images. Press the Delete button again to delete all the images.
You can also delete all the images in the folder by selecting All in this Folder to delete the images.
To delete all the images in the Memory Stick you can select the Format option from the Internal Memory Tool or the Memory Stick Tool Menu to Format the Internal Memory or the Memory Stick.
Thanks for using FixYa.
Jan 27, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
How do I delete all my pics
to delete all your pictures, including protected images you need to format the recording media or memory stick.here's how you do it:
1.touch home to display home settings.
2.touch manage memory (4th icon to the right,at the bottom of the screen that looks like a toolbox).
3.under memory stick tool, select format.
4.touch format and a message would come up on the screen (All data on the Memory Stick will be erased"
5.touch ok to confirm.
...hope this helps. thanks:)
Aug 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
How do you transfer video on the hard drive to the memory stick?
Unable to transfer a video recording made on the hard disk drive to the Memory Stick Duo™ media Solution
sp.gif sp.gif Do the following before attempting to copy movies to the Memory Stick Duo media:
  1. Ensure an Image Database File has been created on the inserted Memory Stick Duo media.
  2. Ensure there is enough space available on the Memory Stick Duo media.
NOTE: For model-specific information about how to transfer a video recording, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Jul 18, 2010 | Sony Handycam® DCRSR45 HDD Camcorder
I have a Kodak M340 and inadvertently deleted the pics on memory card, but they are in the computer. How can I transfer them back to the camera?
Before the transfer, connect your camera cable to the computer, Click on the start icon and connect to the window photo gallery. Right click the image you want to transfer and drag the cursor to "open file location", right click the image again and click on the "send to" option. You will see your camera icon, then click and it will be sent the image you desire. Goodluck. Indicate if this is helpful.
Jan 12, 2010 | Cameras
Flashing message icon
The blinking envelope icon appears to be a reminder that you have your old SMSs still stored on your SIM card, and N96 needs them to be transferred to the phone memory -ether internal, mass storage or memory card- to properly display and manage them. So what you need to do is go to your menu, open Messaging, hit Options, select 'Sim Messages' and then transfer your SMSs to the N96 memory. Then do the same again & delete the SIM messages that will cure the flashing icon.
Nov 08, 2008 | Nokia N96 Smartphone
Camera wont transfer images to laptop
If the camera displays "Communication Error," when trying to download images the main cause for this error is that there are more than 1000 images stored on the memory card. It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
If this is not the case, there are not 1000 or more images on the memory card, try reconnecting the camera to abnother port on the computer, try another cable or another computer. This error can also display when connecting to a direct print printer. Please check with the printer manufacturer for more information on this error.
Sep 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Help me
Make sure your device is under MTP mode...to do that go under the menu settings, usb and device mode and change it to MTP
Assuming that you have windows media player 10.
1. Creating a selection in Windows Media Player
Launch Windows Media Player 10. Click on the Library tab then Add to Library > Add folder and select a folder (e.g. compilation of favourite songs, converted CD, folder of downloaded songs, etc.) from your hard drive (See Image 1). Click OK to confirm your selection. Your folder data will appear in the main window. Repeat the procedure for your other albums.
You can also do this by clicking File > Add to library > Add folder.
When your folders are ready, click-hold to select all your songs and then drag them to the window on the left, as indicated. Select the entire list again and click Now Playing List and select Synch List (See Image 2).
2. Transferring your selection to your MP3 player
Click on the Synchronize tab. Connect your MP3 player to your computer, your player will be automatically recognized by the computer and synchronization (that is file transfer) will begin immediately.
3. Transferring your MP3s to flash memory
Insert the memory card from your MP3 player or MP3 phone into your computer's card reader and open My Computer. Windows XP will automatically recognize your memory card and its icon should appear next to the other icons.
Click on its icon to open your memory card.
Select the MP3 file to transfer. If you want to transfer several files at once, control-click each individual file. In the File Manager window, click Copy File and select the destination folder.
Check this site for more clarification...I hope this helps..
http://technology.sympatico.msn.ca/How+to+transfer+music+to+an+MP3+player+using+Windows+Media+Player+10/How-To/PortableDevices/ContentPosting.aspx?isfa=1&newsitemid=a5dc6462-1612-44e5-a75b-e83cbbd7f373&feedname=HOWTO_PORTABLES_EN&show=False&number=0&showbyline=False&subtitle=&detect=&abc=abc&date=False
I hope this helps
Please rate accordingly
Thank You
Computerrep
Apr 27, 2008 | SanDisk Sansa e250 MP3 Player
How do I the delete images so I can re-use the memory card?
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
