Question about ASI CL51-15 Notebook
How do I refix a loose key on the keyboard
The e key is still working but has become raised and moves from side to side. How do I refix this loose key on the keyboard?
    Problem Solver:
  • 18 Answers
Maybe you have just displased its locks ,press it firmly and see if it clicks
otherwise you have to find an spare one to install after removing the older key in some models the keyboards must be changed throughly
Posted on Nov 16, 2009
Shift key not functioning.
You have selected the wrong keyboard language.
Go to Control Panel select Region and Language. Change the keyboard to your layout. (Probably US).
Nov 16, 2013 | Acer Aspire One PC Notebook
Half keys stoped work
the ribbon cable to your keyboard has come loose fron theconnector on your motherboard
Feb 04, 2013 | HP ProBook 4710s Notebook
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
Keyboard wont work properly takes about 10 sec for the letter to show on the screen after hitting the keyboard, external keyboard works gr8, anyone got any ideas???????
it has a redundancy error. get an expert to loose you keyboard only, clean the flex panel on the keyboard with a clean cloth and use a clean brush to clean the attachment port on the board and refix it back. it will work fine. it is caused by dirt. good luck
Jun 18, 2010 | HP Compaq Presario V5015US Notebook
Lenovo s1o number lock stuck. i am unable to use keyboard. FN key non responsive. any suggestions are appreciated!
Hello
If the key is physically stuck in the "down" or pressed postion, the key may have become disconnected from the mechanism underneath that returns it to the "up" position.
All keys on all keyboards can be removed. This includes laptops. On laptops, the keys typically have less travel (up and down) than a desktop keyboard and the key attaches to the keyboard differently.
In either case, use a small screwdriver or your fingernail and gently lift up on the key - to return it to the "up" position. When in that position, see if the rest of the keyboard works.
If it does, you can simply lift up on the key and remove it from the keyboard. The support that is underneath will either be removed with the key or will remain on the keyboard.
Re-attaching the key involves aligning the key with the ends of the support bracket and snapping it back into place. (Most keyboards have a white plastic structure that forms a X on 2 sides - allowing the key to move up and down.)
With the key removed, look at the edges of the surrounding keys to get an idea of how it attaches, align the parts and press it back into place.
May 04, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Nothing happens when I hit the ''enter'' key on my keyboard - can you help? I use a laptop with an external keyboard - the enter key on the actual laptop works as it should - but for some reason the enter...
If it is still dormant after you power everything down, you probably have not mistakenly hit something. There may be something physically wrong with the key. Try the keyboard on another computer. If the enter key works reliably there, you have quite a puzzle. But if it fails there as well, see whether the enter key moves as smoothly as the other keys. If it is a larger key, it may have an "equlaizer bar" to make it move smoothly that may have become detached. In that case, look at similar keys to figure out how to reassemble it properly. Also look for dirt of any kind under it or between it and nearby keys.
Nov 27, 2009 | Computers & Internet
Monitor turns on and shows nothing
hI,
Plesae try to refix the RAM and it should work.
Aug 12, 2009 | E-Machines eMachines Monitor E15T4
How to refix key of hp 530
you may try to put it back again by try it but it seems not work since you post uyour question here.
here is some risk.
Download the product manual from the hp support site.
read the instruction how to remove your laptops keyboard, after remove fix it, and reinstall it again.
but it pretty risky because i suggest you may want to do it with people who had experience with it.
but my first time i do it myself there was no problem at all. just follow the manual instruction.
Jan 24, 2009 | HP Pavilion dv6000z Notebook
Loose key
Is only the cap loose, but you can still operate that key?
On most laptop keyboards, the letters are caps on the keyboard button. They are held in place by small plastic tabs on the keyboard structure. The cap snaps in place and is held by the tabs. If the tabs are broken, the cap stays loose.
Some keyboards use a small slider that moves as you depress the key, which means you can't glue it.
Laptop keyboards are replaceable and can be purchased cheaply on ebay or some repair sites.
May 13, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
153 people viewed this question
Top ASI Computers & Internet Experts
marley mcelhinney
Are you an ASI Computer and Internet Expert? Answer questions, earn points and help others
