Question about Garden
Lawnmower with 5 hp briggs ad straton engine.starts fine when cold and runs well but if you shut it off ,it won't restart when its hot
    Scholar:
  • 110 Answers
It sounds like the choke is comming on or you are prinming it again? Dont prime a warm engine
Posted on Nov 17, 2009
Cannot restart, without priming, my 8.75 hp Briggs and Stratton engine.
thats common for a old engine to have to choke it to restart it cold or hot
May 31, 2012 | Briggs & Stratton Briggs Stratton...
I have a B/S 22 HP engine and when I try and start it I hear the selonoid pulling in but the engine will not turn. I can do this several time and finally it will start and runs very well. It took the
Is the noise you hear actually the solenoid popping or the starter gear jumping into the flywheel?? You say it finally starts so I am guessing the starter is engaging and actually bumping the flywheel a little. If that is the case it is probably a dragging starter or weak battery. First thing is to be sure the battery is fully charged then see if it will turn over easily. If not you may have a started problem.
Mar 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Briggs&straton model28n707 type0173-01 won't start
Ours did the same thing. It turned out to be a bent push rod. The intake valve keeps seizing after it's shut off. We free the valve, straighten the push rod and it will run till we shut off. Then same thing. Valve seizes and bends the push rod. We have a call into Sears to see if warranty will fix.....
Jun 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Drive and blade engagement shutsdown the engine.
Sounds like the seat safety switch.
Mar 05, 2009 | Poulan Garden
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
