Question about Sanyo DS24425 24" TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
My Sanyo DS24425 TV failed yesterday. I am a ham radio operator and have noticed, after transmitting on the 40 meter band, I have to unplug the TV for about 10 seconds before it will turn on again. I try to remember to unplug the TV set before operating on 40 meters but yesterday I forgot. I have tried placing an RFI filter in the 120 VAC power lead and a large ferrite core over the coaxial cable at the input but the problem persisted.
I tried twice pushing the "reset" button on the remote, as the owners' manual suggests. When turning on the TV I can hear a relay click inside but get no picture and only very faint sound. When the TV is turned off, a dot of light briefly appears on the screen. Other than that brief bit of light, the screen shows no raster.
Does anyone have any ideas?
  • bonnp Mar 15, 2008
    my tv has a similar problem. it is a sanyo DP42746. i have to turn of f and wait any where from 5 minutes to 20 minutes before it will power back on. before it blacks out I can see the picture fizzing out and once that happens, the sound will continue for a while then stop completely as well at that point the only thing I see is just the green led light. sometimes i find that it will come on right away if i change the power outlet but even that doesn't always do the trick. I am upset about this because I have not had much enjoyment out of this tv. i have not even had it for a year. i am very disappointed.
  • vincento May 31, 2008
    my tv has no pictures
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Posted on May 23, 2008
Picture is black audio ok
A good possibility is that the horizontal amplifier is bad.If you are not familiar with tv circuitry you need a tv tech.
Sep 14, 2013 | Sanyo DS24425 24" TV
My Sanyo DS24425 tv is showing red retrace lines across the screen. The picture sometimes fades out and is replaced by these red lines. Can the tv be fixed?
yes it can be fixed. it needs replacement of a component that heats up and often due to heat it loses solid welded connection, if welded properly it returns back to normal, if not it needs replacement with substitute or comparable capacitor item removed Id codes on it
Dec 12, 2010 | Sanyo DS24425 24" TV
Need the code for One For All remote URC-3220 to use on a Sanyo TV Model DS24425
go on line to look for a manual youll be sure to get it they have even older model remote manuals on line for free
Oct 25, 2009 | Sanyo DS24425 24" TV
Have lost the instuction guide to setting up the tv
Click HERE to download instruction manual copy of Sanyo DS24425 TV
Thanks.
Sep 18, 2009 | Sanyo DS24425 24" TV
"reset button"
eat a willie with mayonnaise
Sep 01, 2008 | Sanyo DS24425 24" TV
Tv sanyo DS24425
Are your dvd put on progresive scan,if it does you gotta deactivate in order to get video.Good luck.
May 06, 2008 | Sanyo DS24425 24" TV
Sanyo TV has no picture or sound
better to take this tv to service shop,possibiliy defective or cracked tuner,broken pc board,cold or intermittent solder in power supply or in main board..
Dec 16, 2007 | Sanyo DS24425 24" TV
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
165 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
