Question about Kenmore Oasis HE 27082 Top Load Washer
We have a 2yr old kenmore mod 110.27042603 that is making noise at about the 8 min mark on spin cycle after the water has been pumped out. Seems like pump doesn't shut off when tub is empty.
I have the same problem. Stops on 7 or 8 min and will not spin.
From reading other posts, it appears to be the motor control module which is the brains or motherboard for the washer. I uplug it completely from the wall for 4 hours, plug back in and wash as normal and this has been working every time. This supposedly reboots the computer. Will not work just to unplug and plug back in. From other posts, this problem is supposed to be on recall if the serial number begins with CS or CT but it is supposed to be difficult for the Sears recall line to confirm this (800-659-7026) . I am trying to get it replaced as a recall. Have found on line for $130.
Posted on Nov 16, 2009
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
Mar 30, 2009 | Kenmore 24902 Top Load Washer
Water does not drain, clicking noise heard no spin cycle
REMOVE DEBRIS FROM PUMP LOCATED INSIDE WASHER ,, REMOVE 2 SCREWS HOLDING BOTTOM PANEL,, PUMP IS PLASTIC TURN COUNTER CLOCK WISE AND REMOVE DEBRIS,, BE CAREFULL HAVE ALOT OF TOWLES STILL HOLD 3 GALLONS OF WATER
Nov 22, 2008 | Kenmore 43142 Front Load Washer
Frigidaire front load washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
Jun 13, 2007 | Kenmore 40052
Kenmore Oasis HE 27082 Top Load Washer Logo
336 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
