Question about ASK Proxima Proxima Ultralight X540 Projector Multimedia Projector
Projector keeps shutting down. Machine will run w/o issue and then shuts down. Have cleaned filters and have tried to see if letting it cool off wll help, but problem keeps re occurring.
SOURCE: Panasonic AE900U Projector
If you cant hear the fan running it isnt. While this unit has a quiet fan believe me you will know if its running during normal operation if you listen for it. This would explain your constant shutdownds.
Posted on Nov 01, 2007
Marrie
  • 563 Answers
SOURCE: projector indicates overheating and shut down
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Posted on Apr 21, 2008
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
SOURCE: Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Posted on Oct 02, 2008
SOURCE: Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Posted on Dec 16, 2008
Hoover uh70035b
If it shuts off after being used for a whirl and won't come back on for a while it is probably overheating. The heat sensor shuts the machine off and won't let it turn back on until it cools down. If this is the issue it could be the filters are clogged and not allowing enough airflow to keep the motor cool. Most bag less vacuum filters should be replaced frequently even if they are cleaned regularly.
Oct 30, 2013 | Vacuums
After running for a few minutes it shuts off, won't restart until it cools down
the Projector unit may be overheating due to airflow. ensure that the intake filter is not blocked, remove and clean it and then replace do not run with filter removed as this will cause dust inside your machine. check that none of the airflow slits on the body of the machine are bloced or taped over.
check that the unit has enough airflow around it to keep cool if unsure move the machine to a open space and let it run to see if the problem persits or stops.
if this persists it may mean the overheat cut off switch is defective and keeps activating even though the machine is not overheated.
I hope this helps.
Dec 12, 2010 | Epson PowerLite 51c Multimedia Projector
NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
Jul 20, 2010 | NEC NP1150 Projector
Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Mar 26, 2010 | Optoma EP7155 Projector
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Projector indicates overheating and shut down
HI there
Apr 21, 2008 | Eiki LC-X50M Projector
Mt800 projector
First I would suggest cleaning the filter on the bottom of the unit where the fan inlet is. Over heating can cause many issues with the video controller in the projector, also shortens the life span of the bulb, always let the unit cool down when turning it off (let the fan run when you turn the power of by top button, never unplug and use the power switch on back. until the fan shuts off.)
Nov 24, 2007 | NEC MultiSync MT830 Multimedia Projector
Overheating?
Hey,
I think it's the cooling... Because when i let it cool down after it shuts down for like a few minutes I can boot it back up. But if i try to boot it up right after it shuts down it won't let me. I think it has a built in temperature monitor to make sure it doesn't overheat. I'm going to install some computer fans on the vents of the projector to get some more airflow. Hopefully that will do the trick.
Nov 03, 2007 | CTX Optoma EzPro 680 Multimedia Projector
139 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Lyle Siemens
Lyle Siemens
Steven Wander
Steven Wander
240cpa
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
