Question about IBM NetVista PC Desktop
I had to do a hard shut down on my ibm e machine because the visuals on the moniter were vibrating back and forth and the computer would not respond. When I turned it back on, i got no monitor signal and the computer would only beep about every three seconds.
  • IBM Master
  • 3,051 Answers
Hello there:
this beepiig generally is telling you that you are having
a problem with your video card what you can do is to unplugthe computer and open the case and locate the power supply cable that goes from the power supply to the motherboard and disconnect it
now press in on you power buttom and hold it there for 30 seconds and if you have a reset button do the same
now plug in the cord that you previously disconnected from the motherboard and than plug inthe computer and restart the computer and you should beok but if the beeping continuse than yes you have a video card that is failing you ok?
i hope that this has been very helpful for you
best regards michael
Posted on Nov 16, 2009
The hand wheel is stuck and won't move. machine makes a vibration noise
try working it back and forth it might jst be stuck a little but vibrating might mean you are putting it out of time too.
Jan 19, 2015 | Brother XR9000 Sewing Machine
How can i recover crashed harddrive
What i often do is to start computer then rapidly twist back and forth in one hand the hard drive then you feel and hear it start working once its working recover information you need then bin it as the chances are it will not work again for ever after no matter how much you shake it
Dec 25, 2011 | IBM Computers & Internet
My emachine computer was working then just stopped, when I tried to turn it back on. the moniter is showing no signal received. I have tried checking the VGA connection, changing it out for another, no...
Try your monitor on another machine - if it is working you have operating system/hard drive/motherboard/memory/heating problems. You must work that out if the monitor is good.
Apr 01, 2010 | E-Machines eMachines Desktop PC
Moniter shuts down while playing wow while not in windows mode
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
Dec 26, 2009 | Xerox XA7-17i 17" LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
Washer Tub Balance
A "professional" does not really balance the tub of a front-loader, they balance the washer. You can do this as well... there are 4 feet, just get a level and move feet up or down to get the machine leveled. Check the horizontal level and then the vertical level. Not too hard unless the feet, legs, are rusted shut in which case you can attempt to shim it up. The unit should not rock back and forth at all in any direction when it it leveled. Front loaders will vibrate, sometimes a lot, until they reach the full RPM of the spin, this is normal.
Jul 21, 2009 | Washing Machines
IBM 2647 -41U automatic shut down
How old is your computer??? is it getting overheated?..what operating system did it have before xp? does it give you any messages before shutting down?
let me know
Apr 10, 2009 | IBM ThinkPad T20 2647 Notebook
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
IBM NetVista PC Desktop Logo
62 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
