Braun H2U small electric heater
Electric fan does not work. How do you open the case?
  • 625 Answers
Not sure I have a honeywell and a pelonis heater and both these have screws in recesses in the back.
Posted on Jan 10, 2008
Problem disassembling Braun 4700 series razor
This video should help you in your quest to disassemble your electric shaver
Jan 24, 2014 | Braun 4775 Electric Shaver
What kind of screws are used to open the case on a 6853XL norelco shaver. what ever I use they do not fit
<P>you&nbsp;may be able to&nbsp;use a small flat screwdriver or you can but a tool at shaveroutlet.com.&nbsp; See link below</P><P>&nbsp;</P><P><A href="http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html">http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html</A></P>
Aug 27, 2010 | Norelco ReflexPlus 6853 XL Electric Shaver
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
How does one open the case of a braun multimix 220w - i removed the screw in the front, but something else is holding it together
You need to remove the base plate by carefully prying it open at the opposite end of where the electric cord is fitted. Then release the two halves working along the edges with a thin blunt object. Also carefully remove the sliding cover for the center power mixer outlet before separating the halves.
Jan 01, 2010 | Braun M880 MultiMix Hand Mixer
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
How to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Nov 20, 2008 | Braun Syncro 7526 Electric Shaver
Braun 7526 battery problem
Open the shaver:
4) Open shaver
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Jul 11, 2008 | Braun Flex Integral 6550 Electric Shaver
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
