Question about Bosch 24 in. SHI43 Built-in Dishwasher
Bosch SHI4306 dishwasher not draining properly
I have a bosch SHI4306 dishwasher. it is not completely draining. there is standing water when the wash cycle is finished.
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Posted on May 21, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
Posted on May 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model SHV6803UC/12 - washing
Welcome to FixYa.
I`ll start by letting you know there are many things which can manifest in the manner you`re describing...or even how one interprets what you`re describing.
Having said that are you referring to water in the tub or in fact the "pan" also known as overfill basin ?
**before performing any repairs please turn off the power to the dishwasher...safety first**
In either case I would instruct you to start by checking the drain hose where it is connecting to your home plumbing...i.e. under sink or into food disposer/garberator. for kinks or obstructions.
Also remove the filter assembly and check for food or soap deposits clogging the sump assembly.
**ultimately it may in fact be a faulty drain pump not pumping the adequate volume of water for the time allowed...but I certainly would check the drain first**
That is by far and away the most common cause behind the problem you are describing...based on my understanding as I mentioned.
Let me know if indeed this was helpful or not and we can move forward from here.
Either way thank you for choosing FixYa today. I`ll watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 22, 2010
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Water not draining properly - leaving residue in bottom
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Aug 17, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have a Bosch SHE55C05UC dishwasher and it just started to not wash properly and leave water in the pan below (first time it did not drain at all.. I tried the rinse/hold cycle and got the unit to drain...
I am assuming you have checked the filter and drain sump and there are no obstructions. Have you tried taking the drain pipe out of the sink downpipe and checking if it drains directly into the sink?
I am also assuming the wash cycle is completed when you open the dishwasher.
Do you hear the drain pump running?
Post your comment after you have checked the things I mentioned.
Jun 17, 2010 | Bosch SHE55C05UC Dishwasher
Diswasher is holding water in base after washing, not completely draining what is wrong?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher odor
I have a new Bosch dishwasher which smells up the whole kitchen when the door is opened (between washings). Someone should ban their sales.
May 06, 2007 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch 24 in. SHI43 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
