Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio he toploader leaking on towel/sheet cycle only
I've noticed some leaking on my cabrio top loader under the washer only on one wash type setting- the towels and sheet cycle. If spin is on higher than low spin it is a bad leak- if spin is set to low it is less of a leak. No hoses leaking. Any advice before i call whirlpool once again, this washer has game me nothing but problems since i purchased it in march of 07
  • 1 more comment
  • sissyprims Jan 28, 2008
    sorry it took so long for me to get back to respond- sickness
    thank you for your response, it is on the left side. i will lookinto that, I hate to have to call whirlpool again, it takes them a week to find someone to come to this area and usually that repair guy is so busy it's a month before he gets here. I am calling them in the morning to set up repair, but I am hoping i can do it myself and save the guy a trip and me the wait.
    thanks!
  • Anonymous Jan 30, 2008
    We have exactly the same problem. It leaks on the front left side during the towel/sheet cycle. The repairman told us the drum wasn't cracked and that the machine might be overloaded and that therefore there was nothing to be fixed. But a set of queen-sized sheets and one towel will cause the problem and I don't consider that overloaded. The warranty expires in 2 weeks and we don't know what to do with the repairman saying there isn't a problem.
  • Anonymous Mar 22, 2014
    unit stops spinnig
  • 125 Answers
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Posted on Jan 09, 2008
Cabrio toploader washer, lets cothes wet when machine is finished
Rinse cycle is out. see if you can lift the top of your washer by unscrewing the back or remove the back and you should find the codes and test sheet in there along the inside top edge. Easy to follow if followed by a T.
Jan 19, 2016 | Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer makes a thumping sound
you indicate problem happens on quick wash how about cycle designed for towels ? the control bd on cabrio is programed for loads based on each setting the speed and torgue for motor is controled by the bd and trying to use on settings other than those programed towels may indeed cause problems ..try different cycle and let me know thanks
Jun 24, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
850 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
