Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
    Problem Solver:
  • 4 Answers
I have a wind tunnel and it is so "STOPPED" up that it won't pick up anything ,. How do i un stop it?
Posted on Dec 14, 2009
  • 701 Answers
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Nov 16, 2009
My 1 month old Oreck upright is not sucking in anymore. Worked fine for about 3 weeks. Now it just seems to push stuff around. I'm not sure if it is the bags? Ordered what I was told to order.
The intake tube could very well be clogged. Its pretty simple to disassemble. This happens commonly on Oreck, all you need is for something stiff to get lodged sideways in the tube then everything builds up around it.
Nov 28, 2015 | Oreck Vacuums
Will not pick up dirtO
read the bag. it tells you to change often.
Oct 19, 2009 | Vacuums
Full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
  • Pull the wand out and remove it from the hose by pressing the button on the wand look through the wand
  • Remove the hose from the machine by pinching the hose clamp and pulling the hose out (it simply presses back in when you are done)
  • press on the large button below the bag compartment on the front. (its often a different color and presses difficultly) lift the bag compartment and handle off the powerhead. (replace by simply pressing the bag compartment back onto the head)
  • look down the powerhead and inspect the other areas of the bag compartment.
  • open the orange/gray door on the bottom of the powerhead and look through checking for debris.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
Jun 05, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacum will not pick up
Due to the way carpets are made - new carpets sometimes have a lot of loose fiber. This is NORMAL and it may take 3-5 times to vacuum the carpet till it goes back to normal. Spitting out fuzz balls is a bit weird. Make sure you have the belt installed right - see video on www.goodvac.com. but the fact that belts keep breaking I am assuming that you have them installed right. Give it a few more belts and if the problem presists - let me know.
Rocky
Dec 26, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria doesn't pick up visible dirt
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Dec 08, 2008 | Kirby G6 Bagged Upright Vacuum
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=563001
Generic problem for all Vacuums
posted by smithcarolj1 on May 01, 2008
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and obstructions and there are none. Plus the noise level has increased. What is wrong?
I am very dissatisfied.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem, using the Hoover Windtunnel is a very good vacuum. Reading youre description, the belt is one of the main reasons you are not picking up the small fuzz on a medium shag carpeting. The belt change on the average , if you have one or 2 belts should be changed every 4 to 6 months as a rule, and the brushes need to be in good shape as well, if those two are working well you may have a bad seal on the motor or a broken fan blade(s) and that would decrease suction and you would need to replace the fan. Also check the gaskets if they are broken or damaged or pinched and letting air through the suction will leak out. These are some of the items to check for, so feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
260 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
