Question about Tyan Thunder K7 S2462 (S2462UNG) Motherboard
Using a Tyan Thunder K7 S2462 motherboard, what
Using a Tyan Thunder K7 S2462 motherboard (which has an AGP Pro 2x/4x slot for the graphics card), what reasonably priced graphics cards would run Windows 7 with Aero?
  • Anonymous Mar 28, 2014
    mb lost mac address due to worn-out battery. all 00 now. how to set a new valid address?
Sought advice from others.
Posted on Nov 17, 2009
Tyan S2885 mb and graphics card Asus AH 4650
install agp drivers, ide drivers then video drivers
Feb 04, 2010 | Tyan Thunder K8W S2885 Motherboard
Compatability
You have an AGP expansion slot for a graphics card.
(Accelerated Graphics Port)
It uses either 1x, 2X, or 4X graphics cards. Since the only AGP graphics cards out there are 4X or 8X, the 1X, and 2X are moot points. (They were also Junk anyway!)
Your AGP graphics slot only supports AGP graphics cards that are 1.5 volts. There are AGP graphics cards out there, that are Universal. Universal in that they will run as AGP 8X, (.8 volts), or AGP 4X, (1.5 volts)
This is an example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Don't expect to play the high end new intense games with this. I'm afraid you'll have to update your motherboard, processor, ram memory, and a better graphics card to do that.
(Example? XFX Nvidia nForce 680i LT SLI motherboard, Intel Core2 Duo E8200 cpu, Corsair XMS2 PC6400 ram memory, 1GB x2 of them, (DDR2 at 800MHz), and XFX Geforce 9800GTX+, vid card. (Plus OCZ SteathXStream 600W power supply)
This won't break the bank, and will slam some games to the wall!)
Jun 05, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
About graphics card
Your motherboard supports AGP graphics cards at 1x, 2x, and 4x speed only. You can find great prices on these cards here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1069609639&name=AGP+4X%2f8X
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
The 4X override and fast-writes can't be supported totally in XP..........
first check the bios version and tyan's compatability site for the video cards support...
if all checks well and the bios has been updated ...
then: try running a ps/2 mouse and verify the usb components is not the error....
be sure you have support for 1.0 and 1.1 usb activated for a mouse support.. and keyboard mouse options on in the bios...
is it a mouse error ... or video card error... check for updates on the manufacturers of the mouse if usb...
Apr 27, 2008 | 3Dlabs Oxygen GVX210, (64 MB) Graphic Card
AGP card to replace inboard graphics card
Yes, your GeForce is compatible with the BRIOs AGP 2X port. And there is no problem in using an 8X board in a 4X or 2X AGP slotted motherboard... it would only be a problem if you have a 1X AGP port which is rather old (fisrt agp ports on the market).
Apr 16, 2008 | Computers & Internet
Ati radeon 7000 agp card not recognize by the system
Have you tried cleaning the AGP slot out with a combo of canned air & a clean paint brush? Set the bios for AGP 4X & connect power to the 7200 if power is needed. Still nothing. Try another AGP card.
Jan 13, 2008 | ATI RADEON 7200 (64 MB) Graphic Card
AGP 2X or 4X
if the specs say 4 then it should be 4, however you can plug an 8x in there and it will work, (as they are backward compatible)
the only thing you have to concern yourself with is the slot bars in the slot, and that they match any slots on the card you are going to insert..
If you look in your AGP slot there may be a partition in the slot...
on most newer slots there is no partition in the slot (denotes voltage) If you look on the VGA cards there is most likely TWO slots, which means that the card will fit into ANY AGP slot.. if there is only ONE slot on the Graphics card it is Voltage dependant and must match the partition on the slot (unless there isn't one)
I hope that helps
Dec 04, 2007 | Shuttle AK32E Motherboard
VIDEO CARD COMPATIBILITY
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
Tyan Thunder K7 S2462 (S2462UNG) Motherboard Logo
170 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Andrew Taylor
Andrew Taylor
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
