Question about Sharp AR-C240P Printer
I have a Sharp AR C240P printer. It started printing black in a washed out appearance. It would do this for a print batch, then on the very next batch, just minutes later, it would print fine. Next, when sent a color picture, it would print in all cyan and still bleached out. Then it went to all magenta with dark color and dark black print. I replaced the belt and toner/drum cartridge with a known good unit from another machine. It didn't fix the problem. I rebooted the machine and now it gives the error message SRAM error, missing E. Help!
    Brigadier General:
  • 3,513 Answers
Hi
A drop-on-demand ink jet printing system includes a print head having at least one mixing chamber with a nozzle opening. A plurality of sources of color liquid ink and a source of bleach communicate with the mixing chamber. A flow controller adapted to selectably meter ink from the sources to the mixing chamber, whereby ink droplets of selectable color are prepared in the least one mixing chamber for delivery from the nozzle. The flow controller is further adapted to meter bleach into the mixing chamber after a droplet is delivered from the nozzle opening to thereby neutralize color ink remaining in the mixing chamber sufficiently such that a next desired color can be attained by adding ink of appropriate color to the mixing chamber. The bleach is universal as to the liquid ink colors, wherein all colors are neutralized thereby. There may be a bleach source associated with each liquid ink color. The bleach in each bleach source is color specific to its associated liquid ink color, wherein only selected colors are neutralized thereby.
For the error message SRAM error:-
however most likely the Print Engine Control Board has failed.
Message SRAM Error Mising E. It is Engine Board defect. Just replace the Engine Board.
P/N: 42433206 for C7350
P/N: 41960402 for C7300 with EEPROM
or I believe the ram is either defective, or sometimes u can take it out ans re-seat it.
Thanks for contacting fixya.com
Posted on Nov 16, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
I use my Sharp AR-BC320 as a network printer, how do I set the print mode to default black & white. It is currently set to always print color. I have searched the manual and is says nothing about print...
On the Print Window.
1. Click on the Properties button.
2. Click the Color Tab and Choose the "Print in Grayscale" option and Select "Black ink only"
3. Click the Printing Shortcuts Tab. Click the "Save As" button and assign a shortcut name you can remember.
4. Then click "OK". and print.
5. The next time you print a document just look for that in the printing shortcuts.
Mar 18, 2011 | Sharp AR-BC320 All-In-One Led Printer
My ar-c240p sharp printer prints very nice sharp prints both color and black sometimes. Most of the time it prints light gray and washed out colors. This may happen from on print to another within...
Hello.. Generally when this happens the developer rollers are worn out and need to be replaced. This is a job best left to a trained tech. Thanks for choosing fixya! Regards, Joe
Nov 13, 2009 | Sharp AR-C240P Printer
Sharp AR-C240p change yellow toner counter still say's 0
please dear your yellow toner is not original, so you change it or buy original thanks
Jul 30, 2009 | Sharp AR-C240P Printer
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
PRINTS BLANK(NOTHING APPEARS ON THE PAPER)
I don't know you talking about color printer or black/white or copier that is all difference, if copier, you have go to check the charge&discharge corona wire if black/white printer you have check the image roller both end contact is clean,
Dec 11, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Dec 01, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M237 Copier
you check the optical unit and laser unit glass and cleaning. the next check drum counter process unit counter.
May 10, 2007 | Sharp AR-M237 Copier
Sharp AR-C240P Printer Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
